An overview of the Attribute Rules toolset
The Attribute Rules toolset contains tools for managing geodatabase attribute rules. Attribute rule functionality provides a way to add custom rules and behavior to geodatabase data. With these geoprocessing tools you can incorporate attribute rules into workflows and automate the process of adding and removing rules.
Learn more about working with attribute rules
Tool
Add Attribute Rule
Adds an attribute rule to a dataset.
Alter Attribute Rule
Alters the properties of an attribute rule.
Delete Attribute Rule
Deletes one or more attribute rules from a dataset.
Disable Attribute Rules
Disables one or more attribute rules for a dataset.
Enable Attribute Rules
Enables one or more attribute rules in a dataset
Evaluate Rules
Evaluates geodatabase rules and functionality.
Export Attribute Rules
Exports attribute rules from a dataset to a comma-separated values file (.csv).
Import Attribute Rules
Imports attribute rules from comma-separated value files (.csv) to a dataset.
Reorder Attribute Rule
Reorders the evaluation order of an attribute rule.
Toolset
Templates
The Templates toolset contains tools for creating attribute rules with predefined ArcGIS Arcade templates. An understanding of Arcade is not required to create an attribute rule. The Arcade logic can be modified after rule creation.
