Alter Attribute Rule (Data Management Tools)
Summary
Alters the properties of an attribute rule.
Usage
Parameters
Label Explanation Data type
Input Table
The table containing the attribute rule that will be altered.
Table View
Rule Name
The name of the attribute rule that will be altered.
String
(Optional)
The description of the attribute rule.
To clear the existing value of the description, choose the Reset option from the drop-down menu.
  • Reset—The existing rule description value will be cleared.
String
Error Number
(Optional)
The error number of the attribute rule.
To clear the existing error number value for a calculation rule, choose the Reset option from the drop-down menu. Error number is a required property for constraint and validation rules and cannot be cleared for those rule types.
  • Reset—The existing rule error number value will be cleared.
String
Error Message
(Optional)
The error message of the attribute rule.
To clear the existing error message value for a calculation rule, choose the Reset option from the drop-down menu. Error message is a required property for constraint and validation rules and cannot be cleared for those rule types.
  • Reset—The existing rule error message value will be cleared.
String
Tags
(Optional)
The tags for the attribute rule.
To clear all tags, click the delete button to remove each tag from the list, and choose Reset from the drop-down menu.
  • Reset—The existing rule tags will be cleared.
String
Triggering Events
(Optional)
Specifies the editing events that will trigger the attribute rule to take effect. Triggering events are only applicable for constraint rules and immediate calculation rules.The new values will replace existing triggering events. To keep the existing triggering events, leave this parameter empty.
  • Insert—The rule will be applied when a new feature is added.
  • Update—The rule will be applied when a feature is updated.
  • Delete—The rule will be applied when a feature is deleted.
String
Script Expression
(Optional)
An ArcGIS Arcade expression that defines the rule. To keep the existing expression, leave this parameter empty. If an expression is provided for this parameter, it will replace the existing Arcade expression of the rule. If you alter the script expression of a batch calculation or validation rule, the rule must be reevaluated.
Calculator Expression
Exclude From Client Evaluation
(Optional)
Specifies whether the application will evaluate the rule locally before applying the edits to the workspace.
The default for this parameter corresponds to the existing value set for the rule. That is, if the input rule has the exclude from client evaluation parameter set to false, the default for this parameter will be unchecked so the rule will not be automatically excluded. This parameter is not applicable for validation rules or batch calculation rules.
  • Checked—The rule will be excluded from client evaluation.
  • Unchecked—The rule will not be excluded from client evaluation.
Boolean
Triggering Fields
(Optional)
A list of fields that will trigger an attribute rule to run when an editing event occurs during an update trigger for calculation and constraint attribute rules. If no fields are specified, all fields will be used.
To enter multiple triggering fields, use a semicolon delimiter, for example, Field1;Field2;Field3.
Field
Subtype
(Optional)
The subtype or subtypes to which the rule will be applied.
String
Derived output
Updated Table
The input table with the updated attribute rule properties.
Table View; Raster Layer; Mosaic Layer
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
