Export Attribute Rules (Data Management Tools)
Summary
Exports attribute rules from a dataset to a comma-separated values file (.csv).
Usage
  • This tool can be used in conjunction with the Import Attribute Rules tool.
  • The output .csv file will include the following columns:
    Column
    Example
    NAME
    The name of the rule.
    constraintRuleOP
    DESCRIPTION
    The rule description.
    Operating pressure must be less than 300.
    TYPE
    The type of attribute rule.
    CONSTRAINT, CALCULATION
    SUBTYPE
    If the dataset has a subtype and the subtype is used in the rule definition, this is the subtype name (also known as description) to which the rule is applied.
    ALL
    FIELD
    The name of the field to which the rule is applied, if applicable.
    CONDITION
    ISEDITABLE
    A Boolean value that defines whether the attribute field is editable.
    True or False
    TRIGGERINSERT
    A Boolean value that defines whether the triggering events for the rule are set for insert edits.
    True or False
    TRIGGERDELETE
    A Boolean value that defines whether the triggering events for the rule are set for delete edits.
    True or False
    TRIGGERUPDATE
    A Boolean value that defines whether the triggering events for the rule are set for update edits.
    True or False
    SCRIPTEXPRESSION
    The ArcGIS Arcade script expression that defines the rule.
    $feature.OPERATINGPRESSURE < 300
    ERRORNUMBER
    The error number for the rule, if applicable.
    99
    ERRORMESSAGE
    The error message for the rule, if applicable.
    Invalid operating pressure. The value must be less than 300.
    EXCLUDECLIENTEVALUATION
    A Boolean value that defines whether the rule is supported for all clients or simple clients.
    True or False
    ISENABLED
    A Boolean value that defines whether the attribute rule is enabled.
    True or False
    BATCH
    A Boolean value that defines whether the rule supports batch validation.
    True or False
    SEVERITY
    An integer value (1–5) that defines the severity of the error.
    TAGS
    A set of string values that identify the rule.
    Operating pressure
    CATEGORY
    A system-generated integer value that defines the rule category, if applicable.
    This value is system generated and should not be modified.
    6
    CHECKPARAMETERS
    A system-generated JSON value that defines the configuration of a Data Reviewer-based rule.
    {"ReviewerRuleType": "0", "minimumangle": "60"}
    TRIGGERINGFIELDS
    A list of field values representing the fields where an edit occurs that will trigger the attribute rule.
    An empty array defined as [] represents all fields as triggering fields. When no triggering fields are specified, all fields are listed as triggering fields.
    ["RoadCondition", "NumberOfLanes", "RoadType"]
Parameters
Label Explanation Data type
Input Table
The table or feature class from which the attribute rules will be exported.
Table View
Output File
The folder location and name of the .csv file that will be created.
File
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
