Reorder Attribute Rule (Data Management Tools)
Summary
Reorders the evaluation order of immediate calculation and constraint attribute rules.
The evaluation order controls the sequence in which rules are evaluated. The evaluation order is important when there are dependencies on calculated fields, since the result may be impacted if the rules are in a different order.
Parameters
| Label | Explanation | Data type |
Input Table |
The table that contains the attribute rule with the evaluation order that will be updated. |
Table View |
Rule Name |
The name of the calculation or constraint rule that will have its evaluation order updated. |
String |
Evaluation Order |
The new evaluation order for the rule. For example, if there are five rules and a particular rule is in position 5 (the fifth order position, to be evaluated last) but you want it to be evaluated in position 2 (to be evaluated second), enter 2 for the value. The evaluation order for the rules after position 2 will be reassigned (that is, position 2 becomes position 3, position 3 becomes position 4, and position 4 becomes position 5). |
Long |
Derived output
Updated Table |
The input table with its attribute rule evaluation order updated. |
Table View |
Environments
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
