Evaluate Rules (Data Management Tools)
Summary
Evaluates geodatabase rules and functionality.
Learn more about evaluating attribute rules
Usage
  • If there is a selection in the map, only selected features within the specified extent will be evaluated.
  • When the input workspace is a file or mobile geodatabase, the entire workspace is evaluated.
  • When the input workspace is a feature service workspace, the validation capability must be enabled.
  • The tool evaluates attribute rules for the default version.
    License:
    When working with branch versioning in an ArcGIS Enterprise 11.2 or later deployment, organization members must be assigned a license for the ArcGIS Advanced Editing user type extension to use this tool.
Parameters
Label Explanation Data type
Input Workspace
A file geodatabase, mobile geodatabase, or feature service URL. An example of a feature service URL is https://myserver/server/rest/services/myservicename/FeatureServer.
Workspace
Evaluation Types
Specifies the types of evaluation that will be used.
  • Calculation rules—Batch calculation attribute rules will be evaluated.
  • Validation rules—Validation attribute rules will be evaluated.
String
Extent
(Optional)
The extent to be evaluated. If there is a selection in the map, only selected features within the specified extent will be evaluated.
  • Current Display Extent Map View—The extent will be based on the active map or scene.
  • Draw Extent Square and Finish—The extent will be based on a rectangle drawn on the map or scene.
  • Extent of a Layer Layer—The extent will be based on an active map layer. Choose an available layer or use the Extent of data in all layers option. Each map layer has the following options:
    • All Features Select All—The extent of all features.
    • Selected Features Area from Selected Features—The extent of the selected features.
    • Visible Features Extent Indicator—The extent of visible features.
  • Browse Browse—The extent will be based on a dataset.
  • Intersection of Inputs Intersect—The extent will be the intersecting extent of all inputs.
  • Union of Inputs Union—The extent will be the combined extent of all inputs.
  • Clipboard Paste—The extent can be copied to and from the clipboard.
    • Copy Extent Copy—Copies the extent and coordinate system to the clipboard.
    • Paste Extent Paste—Pastes the extent and coordinate system from the clipboard. If the clipboard does not include a coordinate system, the extent will use the map's coordinate system.
  • Reset Extent Reset—The extent will be reset to the default value.
When coordinates are manually provided, the coordinates must be numeric values and in the active map's coordinate system. The map may use different display units than the provided coordinates. Use a negative value sign for south and west coordinates.
Extent
Async
(Optional)
Specifies whether the evaluation will run synchronously or asynchronously. This parameter is only supported when the input workspace is a feature service.
  • Checked—The evaluation will run asynchronously. This option dedicates server resources to run the evaluation with a longer time-out. Running asynchronously is recommended when evaluating large datasets that contain many features requiring calculation or validation. This is the default.
  • Unchecked—The evaluation will run synchronously. This option has a shorter time-out and is best used when evaluating an extent with a small number of features requiring calculation or validation.
Boolean
Derived output
Updated Workspace
The updated feature service workspace that has been evaluated.
Workspace
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Limited
    Supported for branch versioning when using ArcGIS Enterprise named user licensing with a member that has the ArcGIS Advanced Editing user type extension.
  • Standard: Yes
  • Advanced: Yes
