Delete Attribute Rule (Data Management Tools)
Summary
Deletes one or more attribute rules from a dataset.
Learn more about attribute rules
Usage
  • If you specify both a rule name and a rule type when running this tool, the tool will verify that the rule matches the rule type. If they do not match, the rule will not be deleted.
Parameters
Label Explanation Data type
Input Table
The table or feature class containing the attribute rules that will be deleted.
Table View
Rule Names
The names of the rules that will be deleted from the dataset.
String
Type
(Optional)
Specifies the type of attribute rules that will be deleted.
  • Calculation—Calculation rules, filtered from the Rule Names parameter value, will be deleted .
  • Constraint—Constraint rules, filtered from the Rule Names parameter value, will be deleted.
  • Validation—Validation rules, filtered from the Rule Names parameter value, will be deleted.
  • Calculation—Calculation rules will be deleted.
  • Constraint—Constraint rules will be deleted.
  • Validation—Validation rules will be deleted.
String
Derived output
Attribute Rules Deleted
The updated input table with one or more attribute rules deleted.
Table View; Raster Layer; Mosaic Layer
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
