An overview of the Projections and Transformations toolset
The Projections and Transformations toolset contains tools for converting geographic data between coordinate systems. There are additional tools for transforming raster datasets, such as shift, rescale, and rotate.
When you obtain GIS data, it often needs to be transformed or projected. Since the data you receive is not always preprocessed, you may need to place coordinates in raster images. The transformation tools in the Projections and Transformations toolset can be used to rectify these issues. Whether you treat the earth as a sphere or a spheroid, you must transform its three-dimensional surface to create a flat map sheet. This mathematical transformation is commonly referred to as a map projection.
To understand how transformations work, keep in mind that all places on the earth have a location, and spatial data corresponds to one of these locations. Imagery and raster data that are not preprocessed—meaning they come directly from the sensor or scanner—typically do not have any of these coordinates or locations inherent. You can use the transformation tools to move the image to the proper location and change the image to the proper orientation.
Altering spatial properties using map projections can be described as shining a light through the earth onto a surface called the projection surface. Imagine that the earth's surface is clear, with the graticule drawn on it. Wrap a piece of paper around the earth. A light at the center of the earth will cast the shadows of the graticule onto the piece of paper. You can now unwrap the paper and lay it flat. The shape of the graticule on the flat paper is different from what it was on the earth because the map projection has distorted the graticule.
A spheroid can't be flattened to a plane any more easily than a piece of orange peel can be flattened; it will rip. Representing the earth's surface in two dimensions causes distortion in the shape, area, distance, or direction of the data. A map projection uses mathematical formulas to relate spherical coordinates on the globe to flat, planar coordinates.
Different projections cause different types of distortions. Some projections are designed to minimize the distortion of one or two of the data's characteristics. A projection can maintain the area of a feature but alter its shape.
Tool |
Description |
Changes the coordinate system of a set of input feature classes or feature datasets to a common coordinate system. To change the coordinate system of a single feature class or dataset use the Project tool. |
Converts coordinate notations contained in one or two fields from one notation format to another. |
Creates a transformation definition for converting data between two geographic coordinate systems or datums. The output of this tool can be used as a transformation for any tool with a parameter that requires a geographic transformation. |
Creates a transformation definition for converting data between two vertical coordinate systems or datums. The output of this tool can be used as a transformation object for any tool with a parameter that requires a vertical transformation. |
Creates a spatial reference for use in ModelBuilder. |
Overwrites the coordinate system information (map projection and datum) stored with a dataset. This tool is intended for datasets that have an unknown or incorrect coordinate system defined. |
Projects spatial data from one coordinate system to another. |
An overview of the Raster toolset
The following table summarizes the tools in the Raster toolset (a toolset under the Projections and Transformations toolset). These tools are for projecting and transforming rasters.
Tool |
Description |
Reorients the raster by turning it over, from top to bottom, along the horizontal axis through the center of the raster. This may be useful to correct raster datasets that are upside down. |
Reorients the raster by turning it over, from left to right, along the vertical axis through the center of the raster. |
Transforms a raster dataset from one coordinate system to another. |
Automatically aligns a raster to a reference image or uses a control point file for georegistration. If the input dataset is a mosaic dataset, the tool will operate on each mosaic dataset item. To automatically register the image, the input raster and the reference raster must be in a relatively close geographic area. The tool will run faster if the raster datasets are in close alignment. You may need to create a link file, also known as a control point file, with a few links to get your input raster into the same map space. |
Resizes a raster by the specified x and y scale factors. |
Turns a raster dataset around a specified pivot point. |
Moves (slides) the raster to a new geographic location based on x and y shift values. This tool is helpful if your raster dataset needs to be shifted to align with another data file. |
Transforms a raster dataset using source and target control points. This is similar to georeferencing. |
Transforms a raster dataset using an existing text file containing source and target control points. |
