Create Spatial Reference (Data Management Tools)
Summary
Creates a spatial reference for use in ModelBuilder.
Usage
  • You can create a spatial reference with a set coordinate system, spatial domains, and precision. The spatial domains and precision of the output spatial reference can be further modified using the XY Domain, Z Domain, M Domain, Template XYDomains, and Grow XYDomain By Percentage parameters.
  • XY, Z, and M extents are not the same as spatial reference domains. The XY, Z, and M domains in a spatial reference define the valid range of coordinate values that can be stored in a feature class. The feature class extents reflect the actual range of coordinate values that exist in the feature class. These extents cannot be larger than the domains.
  • The Template XYDomains parameter does not have to be in the same coordinate system as that specified in Spatial Reference or Spatial Reference Template. If they are different, the extents will be projected to match.
  • If the Spatial Reference and Spatial Reference Template parameters are both set, the Spatial Reference parameter will take priority.
  • All the parameters of the tool are optional. If no parameters are specified, the spatial reference will be defined as Unknown, and the XY Domain will assume standard defaults.
  • In ModelBuilder, the output of this tool can be used as input to tools with a spatial reference parameter (for example, Create Feature Class, Create Feature Dataset, and Make XY Event Layer).
  • In Python, the SpatialReference class can also be used to create a spatial reference.
Parameters
Label Explanation Data type
Spatial Reference
(Optional)
The name of the spatial reference to be created.
Spatial Reference
(Optional)
The feature class or layer to be used as a template to set the value for the spatial reference.
Feature Layer; Raster Dataset
XY Domain
(Optional)
The allowable coordinate range for x,y coordinates.
Envelope
Z Domain (min max)
(Optional)
The allowable coordinate range for z-values.
String
M Domain (min max)
(Optional)
The allowable coordinate range for m-values.
String
Template XYDomains
(Optional)
The feature classes or layers that can be used to define the XY Domain.
Feature Layer
(Optional)
The percentage by which the XY Domain will be expanded.
Double
Derived output
Output Spatial Reference
The output spatial reference.
Spatial Reference
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
