Create Feature Class (Data Management Tools)
Summary
Creates an empty feature class in a geodatabase or a shapefile in a folder.
Usage
  • The Feature Class Location parameter value (geodatabase or folder) must already exist.
  • This tool creates only simple feature classes such as point, multipoint, polygon, and polyline.
  • A shapefile created by this tool has an integer field named ID. The ID field is not created when you provide a Template Dataset parameter value.
Parameters
Label Explanation Data type
The enterprise or file geodatabase or the folder in which the output feature class will be created. This workspace must already exist.
Workspace; Feature Dataset
Feature Class Name
The name of the feature class to be created.
String
Geometry Type
(Optional)
Specifies the geometry type of the output feature class.
  • Point—The geometry type will be point.
  • Multipoint—The geometry type will be multipoint.
  • Polygon—The geometry type will be polygon.
  • Polyline—The geometry type will be polyline.
  • Multipatch—The geometry type will be multipatch.
String
Template Datasets
(Optional)
An existing dataset or a list of datasets used as templates to define the attribute fields of the new feature class.
Table View
Has M
(Optional)
Specifies whether the feature class will have linear measurement values (m-values).
  • No—The output feature class will not have m-values. This is the default.
  • Yes—The output feature class will have m-values.
  • Same as the template feature class—The output feature class will have m-values if the dataset specified in the Template Feature Class parameter (template parameter in Python) has m-values.
String
Has Z
(Optional)
Specifies whether the feature class will have elevation values (z-values).
  • No—The output feature class will not have z-values. This is the default.
  • Yes—The output feature class will have z-values.
  • Same as the template feature class—The output feature class will have z-values if the dataset specified in the Template Feature Class parameter (template parameter in Python) has z-values.
String
Coordinate System
(Optional)
The spatial reference of the output feature dataset. On the Spatial Reference Properties dialog box, you can select, import, or create a new coordinate system. To set aspects of the spatial reference, such as the x,y-, z-, or m-domain, resolution, or tolerance, use the Environments dialog box.
This parameter is optional, but providing a value is recommended. If no spatial reference is provided, the output will have an undefined spatial reference.
The spatial reference of the Template Feature Class value has no effect on the output spatial reference. If you want the output to be in the coordinate system of the Template Feature Class value, set the Coordinate System parameter to the spatial reference of the Template Feature Class value.
Spatial Reference
Configuration Keyword
(Optional)
The configuration keyword applies to enterprise geodatabase data only. It determines the storage parameters of the database table.
String
Output Spatial Grid 1
(Optional)
This parameter is not supported. Any value provided will be ignored.
Double
Output Spatial Grid 2
(Optional)
Double
Output Spatial Grid 3
(Optional)
Double
Feature Class Alias
(Optional)
The alternate name for the output feature class that will be created.
String
OID Type
(Optional)
Specifies whether the output Object ID field will be 32 bit or 64 bit.
  • Same as template—The output Object ID field type (32 bit or 64 bit) will be the same as the Object ID field of the first template dataset. This is the default.
  • 64-bit—The output Object ID field will be 64 bit.
  • 32-bit—The output Object ID field will be 32 bit.
String
Derived output
Output Feature Class
The new feature class.
Feature Class
Environments
Output Coordinate System, Geographic Transformations, Output has M values, M Resolution, M Tolerance, Output XY Domain, XY Resolution, XY Tolerance, Default Output Z Value, Output has Z values, Z Tolerance, Z Resolution, Output CONFIG Keyword
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
