Create Feature Dataset (Data Management Tools)
Summary
Creates a feature dataset in the output location: an existing enterprise, file, or mobile geodatabase.
Usage
  • A feature dataset is a collection of related feature classes that share a common coordinate system. Feature datasets are used to organize related feature classes into a common container for building a topology, network dataset, terrain, utility network, trace network, or parcel fabric.
Parameters
Label Explanation Data type
Output Geodatabase
The enterprise, file, or mobile geodatabase where the output feature dataset will be created.
Workspace
Feature Dataset Name
The name of the feature dataset to be created.
String
Coordinate System
(Optional)
The spatial reference of the output feature dataset. On the Spatial Reference Properties dialog box, you can select, import, or create a new coordinate system. To set aspects of the spatial reference, such as the x,y-, z-, or m-domain, resolution, or tolerance, use the Environments dialog box.
This parameter is optional, but providing a value is recommended. To edit the data in a feature dataset, a spatial reference is required.
Spatial Reference
Derived output
Output Feature Dataset
The new output feature dataset.
Feature Dataset
Environments
Current Workspace, Output Coordinate System, XY Resolution, XY Tolerance, M Resolution, M Tolerance, Z Resolution, Z Tolerance
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
