An overview of the Workspace toolset
The Workspace toolset contains tools to create several data storage structures used by ArcGIS.
Tool
Clear Workspace Cache
Clears information about a workspace that has been cached in memory.
Compare Schema
Compares two schema reports or geodatabase schemas and produces a dynamic HTML report comparing the differences.
Convert Schema Report
Converts a JSON or XLSX formatted schema report to another schema report format or to an XML workspace document that can be used to create a geodatabase.
Create Cloud Storage Connection File
Creates a connection file for ArcGIS-supported cloud storage. This tool allows existing raster geoprocessing tools to write cloud raster format (CRF) datasets into the cloud storage bucket or read raster datasets (not limited to CRF) stored in the cloud storage as input. The tool also creates a cloud storage connection file that you can use to access Apache Parquet files for mapping.
Create Database Connection
Creates a file that ArcGIS uses to connect to a database, a cloud data warehouse, or an enterprise geodatabase.
Create Database Connection String
Creates a connection string that geoprocessing tools can use to connect to a database or an enterprise geodatabase.
Create Feature Dataset
Creates a feature dataset in the output location: an existing enterprise, file, or mobile geodatabase.
Create File Geodatabase
Creates a file geodatabase in a folder.
Create Folder
Creates a folder in the specified location.
Create Mobile Geodatabase
Creates a mobile geodatabase.
Create Parquet Cache
Creates a local persistent cache file containing the data from the specified Parquet or GeoParquet file.
Create Spatial Type
Adds the ST_Geometry SQL type, subtypes, and functions to an Oracle or a PostgreSQL database. This allows you to use the ST_Geometry SQL type to store geometries in a database that does not contain a geodatabase. You can also use this tool to upgrade the existing ST_Geometry type, subtypes, and functions in an Oracle or a PostgreSQL database.
Create SQLite Database
Creates a GeoPackage or an SQLite database that contains the ST_Geometry or SpatiaLite spatial type.
Enable Editing Templates
Enables a file or mobile geodatabase to store editing templates.
Export XML Workspace Document
Creates a readable XML document of the geodatabase contents.
Generate Schema Report
Generates an Excel, JSON, PDF, or HTML representation of the geodatabase schema. These formats are output to a target destination folder.
Import XML Workspace Document
Imports the contents of an XML workspace document into an existing geodatabase.
Refresh Excel
Refreshes a Microsoft Excel file in ArcGIS Pro.
Update Geodatabase Connection Properties To Branch
Updates an enterprise geodatabase connection to work with branch versioning.
