Compare Schema (Data Management Tools)
Summary
Compares two schema reports or geodatabase schemas and produces a dynamic HTML report comparing the differences.
Learn more about creating and using schema reports
Usage
  • The tool currently does not support PDF comparisons.
  • To view the dynamic HTML output, an internet connection is required.
  • The tool supports comparing different report types, such as an .xlsx file to a .json file.
Parameters
Label Explanation Data type
Base Source
The geodatabase, geodatabase object, or existing schema report that will be used as the base schema for comparison with the test schema.
Workspace; Feature Dataset; Table; File
Test Source
The geodatabase, geodatabase object, or existing schema report that will be used as the test schema for comparison with the base schema.
Output Location
The folder where the output schema comparison file will be saved.
Folder
Name
The first part of the output .html file name. The output file will have _dynamic.html appended to the specified name.
String
Formats
Specifies the file types that will be included in the output folder.
  • Dynamic HTML—The output folder will include an .html file.
String
Derived output
Out Files
The comparison files.
File
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
