Convert Schema Report (Data Management Tools)
Summary
Converts a JSON or XLSX formatted schema report to another schema report format or to an XML workspace document that can be used to create a geodatabase.
Usage
  • This tool will only run successfully on .json or .xlsx files created by the Generate Schema Report tool.
  • Schema report input must represent a geodatabase workspace. Reports created from feature classes or feature datasets are not valid inputs for this tool.
  • Changes made to the .json or .xlsx files are not validated during the conversion.
Parameters
Label Explanation Data type
Schema Report
The JSON or XLSX schema report that will be converted.
File
Output Location
The folder where the output files will be placed
Folder
Name
The name of the file outputs.
String
Output Formats
Specifies the file types that will be included in the output folder.
  • JSON—The output folder will include a .json file.
  • PDF—The output folder will include a .pdf file.
  • HTML—The output folder will include an .html file.
  • XLSX—The output folder will include an Excel .xlsx file.
  • XML—The output folder will include an .xml file.
  • Dynamic HTML—The output folder will include a dynamic .html file.
String
Derived output
Output Files
The derived file types in the output folder.
File
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
