Generate Schema Report (Data Management Tools)
Summary
Generates an Excel, JSON, PDF, or HTML representation of the geodatabase schema. These formats are output to a target destination folder.
Learn more about generating a schema report
Usage
  • Schema elements in the geodatabase will be included.
  • This tool can be run on a workspace (file, mobile, and enterprise), feature class, feature dataset, feature layer, and feature service.
  • The selected report formats are output to a single folder.
  • Datasets must be registered with the geodatabase.
Parameters
Label Explanation Data type
Input Dataset
The workspace, feature dataset, feature layer, or table view that will be used to generate the schema report.
Workspace; Feature Dataset; Feature Layer; Table View
Output Location
The folder where the report will be created.
Folder
Name
The name of the file outputs.
String
Output Formats
Specifies the file types that will be included in the output folder.
  • JSON—The output folder will include a .json file.
  • PDF—The output folder will include a .pdf file.
  • HTML—The output folder will include an .html file.
  • XLSX—The output folder will include an Excel .xlsx file.
  • Dynamic HTML—The output folder will include a dynamic .html file.
String
Derived output
Output Files
The derived file types in the output folder.
File
Environments
Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
