Create Database Connection (Data Management Tools)
Summary
Creates a file that ArcGIS uses to connect to a database, a cloud data warehouse, or an enterprise geodatabase.
Usage
  • After valid connection information is provided on the tool dialog box to establish a connection, the tool will connect to the database to determine if it contains the geodatabase schema.
    • For databases, all the parameters in the Geodatabase Connection Properties parameter category in the Geoprocessing pane will be ignored.
    • For geodatabases, the tool automatically populates the Geodatabase Connection Properties parameter category. The Schema parameter is set with the sde schema (for Oracle user schema geodatabases only), the default Version Type value for the geodatabase, and the Default version.
  • If you don't want to save the connection information in the Results window or don't want to store it in the geoprocessing history log files, disable all logging options for geoprocessing history and save the connection file without saving the connection information.
  • Connections from ArcGIS to Altibase and Netezza are no longer supported.
Parameters
Label Explanation Data type
Connection File Location
The folder path where the database connection file (.sde or .dbconn) will be stored.
Folder
Connection File Name
The name of the database connection file. The output file will have the .sde extension.
String
Database Platform
Specifies the database management system platform to which the connection will be made. The following are valid options:
  • BigQuery—The connection will be made to Google BigQuery.
  • Dameng—The connection will be made to Dameng.
  • Db2—The connection will be made to IBM Db2 for Linux, UNIX, or Windows.
  • Elasticsearch—The connection will be made to Elasticsearch.
  • OpenSearch—The connection will be made to OpenSearch.
  • Oracle—The connection will be made to Oracle, Amazon Relational Database Service (RDS) for Oracle, or Autonomous Transaction Processing.
  • PostgreSQL—The connection will be made to PostgreSQL, Amazon Aurora (PostgreSQL-compatible edition), Amazon Relational Database Service (RDS) for PostgreSQL, Google Cloud SQL for PostgreSQL, Microsoft Azure Database for PostgreSQL, or Microsoft Azure Cosmos DB for PostgreSQL.
  • Redshift—The connection will be made to Amazon Redshift.
  • SAP HANA—The connection will be made to SAP HANA or SAP HANA Cloud.
  • Snowflake—The connection will be made to Snowflake.
  • SQL Server—The connection will be made to Microsoft SQL Server, Microsoft Azure SQL Database, Microsoft Azure SQL Managed Instance, Amazon Relational Database Service (RDS) for SQL Server, or Google Cloud SQL for SQL Server.
  • Teradata—The connection will be made to Teradata Vantage.
String
Instance/Server
(Optional)
The database server or instance to which the connection will be made.
The value you choose from the Database Platform drop-down list indicates the type of database or cloud data warehouse to which the connection will be made. The information you provide for the Instance/Server parameter will vary, depending on the database platform type that you choose.
See below for information about what to provide for each platform.
  • Dameng—The name of the server where the Dameng database is installed
  • Db2—The name of the cataloged Db2 database
  • Elasticsearch—Not supported
  • OpenSearch—Not supported
  • Oracle—Either the TNS name or the Oracle Easy Connection string to connect to the Oracle database or database service
  • PostgreSQL—The name of the server where PostgreSQL is installed or the name of the PostgreSQL database service instance
  • Redshift—The URL for the Redshift server
  • SAP HANA—The Open Database Connectivity (ODBC) data source name for the SAP HANA database or database service
  • Snowflake—The URL of the Snowflake server
  • SQL Server—The name of the SQL Server database instance or the name of the database service instance
  • Teradata—The ODBC data source name for the Teradata database
String
Database Authentication
(Optional)
Specifies the type of authentication that will be used.
  • Checked—Database authentication will be used. An internal database username and a password will be used to connect to the database. You aren't required to provide your username and password to create a connection; however, if you don't, you will be prompted to enter them when a connection is established.
    If the connection file you are creating will provide ArcGIS services with access to the database or geodatabase, or if you want to use the Catalog search to locate data accessed through this connection file, you must include a username and password.
  • Unchecked—Operating system authentication will be used. You do not need to provide a username and password. The connection will be made with the username and password that were used to log in to the operating system. If the login used for the operating system is not a valid database login, the connection will fail.
Boolean
Username
(Optional)
The database username that will be used for database authentication.
String
Password
(Optional)
The database user password that will be used for database authentication.
Encrypted String
Save username and password
(Optional)
Specifies whether the username and password will be saved.
  • Checked—The username and password will be saved in the connection file. This is the default. If the connection file you are creating will provide ArcGIS services with access to the database, geodatabase, or cloud data warehouse, or if you want to use the Catalog search to locate data accessed through this connection file, you must save the username and password.
  • Unchecked—The username and password will not be saved in the connection file. Every time you attempt to connect using the file, you will be prompted for the username and password.
    ArcGIS Pro caches credentials for the first successful database connection for which you do not save the username and password. If you create a second connection to the same database, geodatabase, or cloud data warehouse instance in the same ArcGIS Pro session and do not save credentials, the cached credentials from the first connection will be used even if you provide different credentials in the second connection file. To connect with different credentials without saving the username and password, start a new ArcGIS Pro session.
Boolean
Database
(Optional)
The name of the database to which the connection will be made. This parameter applies to PostgreSQL, Redshift, Snowflake, and SQL Server platforms.
String
Schema (Oracle user schema geodatabases only)
(Optional)
User-schema geodatabases are no longer supported.
String
Version Type
(Optional)
Specifies the type of version to which the connection will be made. This parameter only applies when connecting to a geodatabase.
If Historical is selected and no name is provided, the default transactional version will be used. If Point in time is selected and no date is provided for the Date and Time parameter, the default transactional version will be used.
  • Transactional—The connection will be made to a transactional version. If Transactional is selected, the The following version will be used parameter will be populated with a list of transactional versions, and the Date and Time parameter will be inactive. This is the default.
  • Historical—The connection will be made to an historical marker. If Historical is selected, the The following version will be used parameter will be populated with a list of historical markers, and the Date and Time parameter will be inactive.
  • Point in time—The connection will be made to a specific point in time. If Point in time is selected, the The following version will be used parameter will be inactive, and the Date and Time parameter will become active.
  • Branch—The connection will be made to the default branch version.
String
(Optional)
The geodatabase transactional version or historical marker to which the connection will be made. The default option uses the default transactional version.
If you choose a branch version type, the connection is always to the default branch version.
String
Date and Time
(Optional)
The value representing the date and time that will be used to connect to the database. This parameter is used with archive-enabled data. Use the time picker to choose the appropriate date.
If manually entering a date, the following formats can be used:
  • 6/9/2011 4:20:15 PM
  • 6/9/2011 16:20:15
  • 6/9/2011
  • 4:20:15 PM
  • 16:20:15
  • If a time is entered without a date, the default date of December 30, 1899, will be used.
  • If a date is entered without a time, the default time of 12:00:00 AM will be used.
Date
Advanced Authentication Type
(Optional)
Specifies the advanced authentication type that will be used when connecting to a cloud data warehouse, Microsoft Azure SQL Database, Azure SQL Managed Instance, Elasticsearch, or OpenSearch.
  • Microsoft Entra MFA—The Microsoft Entra multifactor authentication (MFA) username authentication type will be used, but not the password. When you connect, a code is sent to you in a text message, email, or MFA device, or it can use a fingerprint scan for authentication. This second part of the authentication process varies depending on how your network and authentication protocols are configured. This option is supported for Azure SQL Database and Azure SQL Managed Instance only.
  • Microsoft Entra Password—The Microsoft Entra Password authentication type, which requires username and password parameter values, will be used. Usernames can be a maximum of 30 characters. This option is supported for Azure SQL Database and Azure SQL Managed Instance only.
  • Microsoft Entra Integrated—The Microsoft Entra Integrated authentication type will be used. You do not need to provide a username and password. The connection will be made with the username and password that were used to log in to the operation system. This option is supported for Azure SQL Database and Azure SQL Managed Instance only.
  • Service Authentication—The service authentication type when connecting to Google BigQuery will be used. See Google BigQuery documentation about authentication for information.
  • Standard—The standard authentication type when connecting to Amazon Redshift will be used. See the Amazon Redshift ODBC Data Connector Installation and Configuration Guide for information about standard authentication.
  • User—An authentication method that requires a username and password when connecting to Snowflake will be used.
  • User Authentication—The user authentication type when connecting to Google BigQuery will be used. See Google BigQuery documentation about authentication for information.
  • Basic—An authentication method that requires a username and password when connecting to Elasticsearch or OpenSearch will be used.
String
Project ID
(Optional)
The project ID for the Google BigQuery connection. Public data projects are not supported.
String
Default Dataset
(Optional)
The default dataset for the Google BigQuery connection. Provide the dataset name only; the fully-qualified dataset name is not supported. The dataset name must contain 32 characters or fewer. Public datasets are not supported.
String
Refresh Token
(Optional)
The refresh token value.
This parameter is only applicable for Google BigQuery connections when the advanced authentication type is user authentication.
Encrypted String
Key File
(Optional)
The key file value.
This parameter is only applicable for Google BigQuery connections when the advanced authentication type is server authentication.
File
Role
(Optional)
The role value for a cloud data warehouse connection.
This parameter is only applicable for connections to Snowflake.
String
Warehouse
(Optional)
The warehouse value for the connection.
String
Advanced Options
(Optional)
The advanced options for the connection. This is optional connection information that is specific to the cloud data warehouse platform (Google BigQuery, Amazon Redshift, or Snowflake) to which you connect. Provide advanced options using option=<value> separated by semicolons, for example, option1=value1;option2=value2;. Consult the cloud data warehouse documentation for information about optional connection options.
String
Host URL
(Optional)
The URL to connect to Elasticsearch or OpenSearch.
This parameter is only applicable for connections to Elasticsearch or OpenSearch.
String
Derived output
Output Workspace
The output database connection file (.sde or .dbconn).
Workspace
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
