Create File Geodatabase (Data Management Tools)
Summary
Creates a file geodatabase in a folder.
Usage
  • The output path must already exist.
  • If the output geodatabase name does not include the .gdb extension, it will be added.
Parameters
Label Explanation Data type
File Geodatabase Location
The folder where the file geodatabase will be created.
Folder
File GDB Name
The name of the file geodatabase to be created.
String
File Geodatabase Version
(Optional)
Specifies the ArcGIS version for the new geodatabase.
  • Current—A geodatabase compatible with the currently installed version of ArcGIS will be created. This is the default.
  • 10.0—A geodatabase compatible with ArcGIS version 10 will be created.
  • 9.3—A geodatabase compatible with ArcGIS version 9.3 will be created.
  • 9.2—A geodatabase compatible with ArcGIS version 9.2 will be created.
String
Derived output
Output File Geodatabase
The new output file geodatabase.
Workspace
Environments
Current Workspace, Scratch Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
