Create SQLite Database (Data Management Tools)
Summary
Creates a GeoPackage or an SQLite database that contains the ST_Geometry or SpatiaLite spatial type.
Usage
  • The Output Database Name parameter value will be automatically assigned an extension based on the value of the Spatial Type parameter. If the spatial type parameter value is ST_Geometry or SpatiaLite, the output name will have an .sqlite extension. If the spatial type parameter value is GeoPackage, the output name will have a .gpkg extension.
Parameters
Label Explanation Data type
The location of the SQLite database or GeoPackage that will be created and the name of the file. The .sqlite extension will be automatically assigned if the Spatial Type parameter value is ST_Geometry or SpatiaLite. If the Spatial Type parameter value is GeoPackage or any of the GeoPackage versions, the .gpkg extension will be automatically assigned.
File
Spatial Type
(Optional)
Specifies the spatial type that will be installed with the new SQLite database or the GeoPackage version that will be created.
  • ST_Geometry—The Esri spatial storage type will be installed. This is the default.
  • SpatiaLite—SpatiaLite spatial storage type will be installed.
  • GeoPackage (the latest GeoPackage version supported by ArcGIS)—The latest version of OGC GeoPackage that is supported by ArcGIS will be created.
  • GeoPackage 1.0—An OGC GeoPackage 1.0 dataset will be created.
  • GeoPackage 1.1—An OGC GeoPackage 1.1 dataset will be created.
  • GeoPackage 1.2.1—An OGC GeoPackage 1.2.1 dataset will be created.
  • GeoPackage 1.3—An OGC GeoPackage 1.3 dataset will be created.
  • GeoPackage 1.4—An OGC GeoPackage 1.4 dataset will be created.
String
Environments
Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
