Create Spatial Type (Data Management Tools)
Summary
Adds the ST_Geometry SQL type, subtypes, and functions to an Oracle or a PostgreSQL database. This allows you to use the ST_Geometry SQL type to store geometries in a database that does not contain a geodatabase. You can also use this tool to upgrade the existing ST_Geometry type, subtypes, and functions in an Oracle or a PostgreSQL database.
Usage
Parameters
Label Explanation Data type
Input Database Connection
The input_database is the database connection file (.sde) that connects to the Oracle or PostgreSQL database. You must connect as a database administrator user; in Oracle, you must connect as the sys user.
Workspace
SDE User Password
The password for the sde database user. If the sde user does not exist in the database, it will be created and will use the password you provide. The password policy of the underlying database will be enforced. If the sde user does exist in the database or database cluster, this password must match the existing password.
Encrypted String
Tablespace Name
(Optional)
The name of a tablespace that will be set as the default tablespace for the sde user in Oracle. If the tablespace name does not exist, it will be created in the Oracle default storage location. If a tablespace with the specified name does exist, it will be set as the sde user's default.
String
ST_Geometry Shape Library Path
(Optional)
The location on the Oracle server where the st_shape library resides.
File
Derived output
Output Workspace
The updated database.
Workspace
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
