Make XY Event Layer (Data Management Tools)
Summary
Creates a point event layer from a table containing fields with x- and y-coordinate values, and optionally, z-coordinate (elevation) values.
Usage
The output event layer created by this tool is temporary and is not stored on disk or in a geodatabase. You can export an event layer to a feature class to permanently store it using the Copy Features, Feature To Point, or Export Features tool.
If you are working with tabular data that updates often, you can create an event layer that updates automatically when the source table updates. This may be more efficient than repetitively converting the table to a new point feature class.
Event layer features are not editable. Copy or export the event layer to a feature class if editing is required.
The standard delimiter for tabular text files with a
.csvor.txtextension is a comma, and for files with a.tabextension, a tab. To use an input table with a nonstandard delimiter, you must first specify the correct delimiter used in the table using aschema.inifile.If the input table is from a file format that does not have an Object ID field or a database table without a primary key, you cannot make selections, apply definition queries or other filters, or add joins or relates to the event layer.
Parameters
| Label | Explanation | Data type |
Input Table |
The table containing the x- and y-coordinates that define the locations of the point features that will be created. |
Table View |
X Field |
The field in the input table that contains the x-coordinates (longitude). |
Field |
Y Field |
The field in the input table that contains the y-coordinates (latitude). |
Field |
Output Layer Name |
The name of the output event layer. |
Feature Layer |
Coordinate System (Optional) |
The coordinate system of the coordinates specified in the X Field and Y Field parameters. This will be the output event layer's coordinate system. |
Spatial Reference |
Z Field (Optional) |
The field in the input table that contains the z-coordinates. |
Field |
Environments
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
