An overview of the Layers and Table Views toolset
The Layers and Table Views toolset contains tools for creating and manipulating layers, layer files, and table views.
Layers can reference many data types such as feature classes, CAD data, CAD drawings, shapefiles, TINs, raster datasets, and raster bands. Layers are used to add support for symbology and selections to the data on disk.
Tool |
Description |
Applies the symbology from a specified layer or layer file to the input. It can be applied to feature, raster, network analysis, TIN, and geostatistical layers. |
Creates a definition query (in SQL format) from the selected features or rows of the layer or table. |
Creates a query layer that summarizes, aggregates, and filters DBMS tables dynamically based on time, range, and attribute queries from a related table, and joins the result to a feature layer. |
Creates a composite building layer from a dataset, either a BIM file workspace or a geodatabase dataset, such as the output of the BIM File To Geodatabase tool. |
Creates a feature layer from a feature class or layer file. The layer that is created is temporary and will not persist after the session ends unless the layer is saved to disk or the map document is saved. |
Creates a temporary raster layer from an image service. The layer that is created will not persist after the session ends unless the document is saved. |
Creates a LAS dataset layer that can apply filters to LAS points and control the enforcement of surface constraint features. |
Creates a mosaic layer from a mosaic dataset or layer file. The layer that is created by the tool is temporary and will not persist after the session ends unless the layer is saved as a layer file or the map is saved. |
Creates a query layer from a DBMS table based on an input SQL select statement. |
Applies an SQL query to a database, and the results are represented in either a layer or table view. The query can be used to join several tables or return a subset of fields or rows from the original data in the database. |
Creates a raster layer from an input raster dataset or layer file. The layer created by the tool is temporary and will not persist after the session ends unless the layer is saved to disk or the map document is saved. |
Creates a scene layer from a scene layer package ( |
Creates a table view from an input table or feature class. The table view that is created is temporary and will not persist after the session ends unless the document is saved. |
Creates a triangulated irregular network (TIN) layer from an input TIN dataset or layer file. The layer that is created by the tool is temporary and will not persist after the session ends unless the layer is saved to disk or the map document is saved. |
Creates a temporary raster layer from a WCS service. |
Creates a point event layer from a table containing fields with x- and y-coordinate values, and optionally, z-coordinate (elevation) values. |
Creates unique value symbology for the input layer based on the input field or expression by matching input field or expression strings to symbol names from the input style. |
Creates an output layer file ( |
Adds, updates, or removes a selection based on an attribute query. |
Selects features based on a spatial relationship to features in another dataset or the same dataset. |
