Make WCS Layer (Data Management Tools)
Summary
Creates a temporary raster layer from a WCS service.
Usage
  • This is one of the few tools that can accept a WCS service as an input; therefore, this tool can be used to convert a WCS service to a raster layer, which can then be used by a geoprocessing tool. The layer created by the tool is temporary and will not persist after the session ends unless the document is saved.
  • The input can also be a URL to a WCS server. The WCS server URL should also include the coverage and version information. If only URL is entered, the tool will automatically take the first coverage and use the default version (1.0.0) to create the WCS layer.
  • The output can be the entire image service or a portion of it.
  • You can clip out a portion of the image service by choosing an output extent layer or by specifying the rectangle extent. If you choose an output extent layer, the clip extent will be based on the extent of that layer.
  • The output can be created with only a subset of the bands. This will save time and disk space.
Parameters
Label Explanation Data type
Input WCS Coverage
Browse to the input WCS service. This tool can also accept a URL that references the WCS service.
If a WCS server URL is used, the URL should include the coverage name and version information. If only the URL is entered, the tool will automatically take the first coverage and use the default version (1.0.0) to create the WCS layer.
An example of a URL that includes the coverage name and version is http://ServerName/arcgis/services/serviceName/ImageServer/WCSServer?coverage=rasterDRGs&version=1.1.1.
In this example, http://ServerName/arcgis/services/serviceName/ImageServer/WCSServer? is the URL. The coverage specified is coverage=rasterDRGs, and the version is &version=1.1.1.
To get the coverage names on a WCS server, use the WCS GetCapabilities request. An example of WCS request is http://ServerName/arcgis/services/serviceName/ImageServer/WCSServer?request=getcapabilities&service=wcs.
WCS Coverage; String
Output WCS Layer
The name of the output WCS layer.
Raster Layer
Template Extent
(Optional)
The output extent of the WCS layer.
  • Current Display Extent Map View—The extent will be based on the active map or scene.
  • Draw Extent Square and Finish—The extent will be based on a rectangle drawn on the map or scene.
  • Extent of a Layer Layer—The extent will be based on an active map layer. Choose an available layer or use the Extent of data in all layers option. Each map layer has the following options:
    • All Features Select All—The extent of all features.
    • Selected Features Area from Selected Features—The extent of the selected features.
    • Visible Features Extent Indicator—The extent of visible features.
  • Browse Browse—The extent will be based on a dataset.
  • Clipboard Paste—The extent can be copied to and from the clipboard.
    • Copy Extent Copy—Copies the extent and coordinate system to the clipboard.
    • Paste Extent Paste—Pastes the extent and coordinate system from the clipboard. If the clipboard does not include a coordinate system, the extent will use the map's coordinate system.
  • Reset Extent Reset—The extent will be reset to the default value.
When coordinates are manually provided, the coordinates must be numeric values and in the active map's coordinate system. The map may use different display units than the provided coordinates. Use a negative value sign for south and west coordinates.
Extent
Bands
(Optional)
The bands that will be exported for the layer. If no bands are specified, all the bands will be used in the output.
Value Table
Environments
Extent, Geographic Transformations, Output Coordinate System
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
