Make Image Server Layer (Data Management Tools)
Summary
Creates a temporary raster layer from an image service. The layer that is created will not persist after the session ends unless the document is saved.
The input can also be a SOAP URL to an image server.
Usage
  • Use this tool to create an image layer from an image service or a URL that references an image service.
  • The output can be the entire image service or a portion of it.
  • Use this tool to add an image service to a Python script or model or when creating a geoprocessing service.
  • You can clip out a portion of the image service by choosing an output extent layer or by specifying the rectangle extent. If you choose an output extent layer, the clip extent will be based on the extent of that layer.
  • The output can be created with only a subset of the bands. This will help save on time and disk space.
  • The mosaicking options are only available when the image service it contains is generated from a mosaic definition or an image service definition.
Parameters
Label Explanation Data type
Input Image Service
The name of the input image service or the SOAP URL that references the image service. Browse to or type the input image service. This tool can also accept a SOAP URL that references the image service.
An example of using the image service name called ProjectX is: C:\MyProject\ServerConnection.ags\ProjectX.ImageServer.
An example of a URL is http://AGSServer:8399/arcgis/services/ISName/ImageServer.
Image Service; String
Output Image Server Layer
The name of the output image layer.
Raster Layer
Template Extent
(Optional)
The output extent of the image layer.
  • Current Display Extent Map View—The extent will be based on the active map or scene.
  • Draw Extent Square and Finish—The extent will be based on a rectangle drawn on the map or scene.
  • Extent of a Layer Layer—The extent will be based on an active map layer. Choose an available layer or use the Extent of data in all layers option. Each map layer has the following options:
    • All Features Select All—The extent of all features.
    • Selected Features Area from Selected Features—The extent of the selected features.
    • Visible Features Extent Indicator—The extent of visible features.
  • Browse Browse—The extent will be based on a dataset.
  • Clipboard Paste—The extent can be copied to and from the clipboard.
    • Copy Extent Copy—Copies the extent and coordinate system to the clipboard.
    • Paste Extent Paste—Pastes the extent and coordinate system from the clipboard. If the clipboard does not include a coordinate system, the extent will use the map's coordinate system.
  • Reset Extent Reset—The extent will be reset to the default value.
When coordinates are manually provided, the coordinates must be numeric values and in the active map's coordinate system. The map may use different display units than the provided coordinates. Use a negative value sign for south and west coordinates.
Extent
Bands
(Optional)
The bands that will be exported for the layer. If no bands are specified, all the bands will be used in the output.
Value Table
Mosaic Method
(Optional)
The mosaic method defines how the mosaic is created from different rasters.
  • Seamline—Smooth transitions between images using seamlines.
  • Northwest—Display imagery that is closest to the northwest corner of the mosaic dataset boundary.
  • Center—Display imagery that is closest to the center of the screen.
  • Lock raster—Select specific raster datasets to display.
  • By attribute—Display and prioritize imagery based on a field in the attribute table.
  • Nadir—Display the rasters with viewing angles closest to zero.
  • Viewpoint—Display imagery that is closest to a selected viewing angle.
  • None—Order rasters based on the ObjectID in the mosaic dataset attribute table.
String
Order Field
(Optional)
The default field to use to order the rasters when the mosaic method is By_Attribute. The list of fields is defined as those in the service table that are of type metadata and are integer (for example, the values can represent dates or cloud cover percentage).
String
Order Base Value
(Optional)
The images are sorted based on the difference between this input value and the attribute value in the specified field.
String
Lock Raster ID
(Optional)
The raster ID or raster name to which the service should be locked, such that only the specified rasters are displayed. If left blank (undefined), it will be similar to the system default. Multiple IDs can be defined as a semicolon-delimited list.
String
Output Cell Size
(Optional)
The cell size for the output image service layer.
Double
Expression
(Optional)
Define a query using SQL or use the Query Builder to build a query.
SQL Expression
Processing Template
(Optional)
The raster function processing template that can be applied on the output image service layer.
  • None—No processing template.
String
Environments
Extent, Geographic Transformations, Output Coordinate System
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
