Make Scene Layer (Data Management Tools)
Summary
Creates a scene layer from a scene layer package (.slpk) or scene service.
Usage
  • The temporary scene layer can be saved as a layer file using the Save To Layer File tool.
  • To create a point or 3D object scene layer with an associated feature layer, share the web layer or web scene to a portal.
  • Scene layers can be identified in a global or local scene using the isSceneLayer property in the arcpy Layer class.
  • For more information about scene layers, see What is a scene layer?
  • The properties and methods available on a scene layer depend on the scene layer type and are available through ArcPy functions or the Esri Cartographic Information Model (CIM). Additional CIM properties for each scene layer type are available that aren't exposed through ArcPy functions. See Python CIM access for more information about accessing a layer's CIM. If the scene layer has an associated feature layer, the scene layer can also be used as input to any geoprocessing tool that supports the scene layer's geometry type.
    Scene layer type
    Supports associated feature layer
    3D Object
    Yes
    Point
    Yes
    Point Cloud
    No
    Integrated Mesh
    No
    Building
    Yes
Parameters
Label Explanation Data type
Input Dataset
The input scene layer package (.slpk) or scene service from which the new scene layer will be created.
Scene Layer; Building Scene Layer; File
Output Layer
The name of the scene layer to be created.
Scene Layer
Environments
Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
