Warp From File (Data Management Tools)
Summary
Transforms a raster dataset using an existing text file containing source and target control points.
Illustration
Example of two-dimensional coordinate transformations
Usage
  • Warp is useful when the raster requires a systematic geometric correction that can be modeled with a polynomial. A spatial transformation can invert or remove a distortion using polynomial transformation of the proper order. The higher the order, the more complex the distortion that can be corrected. The higher orders of polynomial will involve progressively more processing time.
  • The default polynomial order will perform an affine transformation.
  • To determine the minimum number of links necessary for a given order of polynomial, use the following formula:
    \(n \space = \space (p \space + \space 1) \space (p \space + \space 2) \space / \space 2\)
    where n is the minimum number of links required for a transformation of polynomial order p. It is suggested that you use more than the minimum number of links.
  • This tool will determine the extent of the warped raster and will set the number of rows and columns to be about the same as in the input raster. Some minor differences may be due to the changed proportion between the output raster's sizes in the x and y directions. The default cell size used will be computed by dividing the extent by the previously determined number of rows and columns. The value of the cell size will be used by the resampling algorithm.
    If you choose to define an output cell size in the Environment settings, the number of rows and columns will be calculated as follows:
  • You can save the output to BIL, BIP, BMP, BSQ, DAT, Esri Grid, GIF, IMG, JPEG, JPEG 2000, PNG, TIFF, MRF, or CRF format, or any geodatabase raster dataset.
  • When storing a raster dataset to a JPEG format file, a JPEG 2000 format file, or a geodatabase, you can specify a Compression Type value and a Compression Quality value in the geoprocessing environments.
  • Each row in the input link file should have the following values, each delimited by a TAB:
    <From X> <From Y> <To X> <To Y>
    where each row represents the coordinates of a control point pair. There can be additional columns with residual values, but these are not required.
  • This tool supports multidimensional raster data. To run the tool on each slice in the multidimensional raster and generate a multidimensional raster output, be sure to save the output to CRF.
    Supported input multidimensional dataset types include multidimensional raster layer, mosaic dataset, image service, and CRF.
Parameters
Label Explanation Data type
Input Raster
The raster to be transformed.
Mosaic Layer; Raster Layer
Output Raster Dataset
The name, location, and format for the dataset you are creating. When storing a raster dataset in a geodatabase, do not add a file extension to the name of the raster dataset. When storing your raster dataset to a JPEG file, a JPEG 2000 file, a TIFF file, or a geodatabase, you can specify a compression type and compression quality using environment settings.
  • .bil—Esri BIL
  • .bip—Esri BIP
  • .bmp—BMP
  • .bsq—Esri BSQ
  • .dat—ENVI DAT
  • .gif—GIF
  • .img—ERDAS IMAGINE
  • .jpg—JPEG
  • .jp2—JPEG 2000
  • .png—PNG
  • .tif—TIFF
  • .mrf—MRF
  • .crf—CRF
  • No extension for Esri Grid
Raster Dataset
Link File
The text, CSV file, or TAB file containing the coordinates to warp the input raster. This can be generated from the Register Raster tool or from the Georeferencing tab.
Text File
Transformation Type
(Optional)
Specifies the transformation method for shifting the raster dataset.
  • Shift only—A zero-order polynomial will be used to shift the data. This is commonly used when the data is georeferenced, but a small shift will better line it up. Only one link is required to perform a zero-order polynomial shift.
  • Similarity transformation—A first order transformation will be used that attempts to preserve the shape of the original raster. The RMS error tends to be higher than other polynomial transformations because the preservation of shape is more important than the best fit.
  • Affine transformation—A first-order polynomial (affine) will be used to fit a flat plane to the input points.
  • Second-order polynomial transformation—A second-order polynomial will be used to fit a somewhat more complicated surface to the input points.
  • Third-order polynomial transformation—A third-order polynomial will be used to fit a more complicated surface to the input points.
  • Optimize for global and local accuracy—A polynomial transformation is combined with a triangulated irregular network (TIN) interpolation technique that will optimize both global and local accuracy.
  • Spline transformation—The source control points will be transformed precisely to the target control points. In the output, the control points will be accurate, but the raster pixels between the control points will not.
  • Projective transformation—Lines will be warped so that they remain straight. Lines that were once parallel may no longer remain parallel. The projective transformation is especially useful for oblique imagery, scanned maps, and for some imagery products.
String
Resampling Technique
(Optional)
The resampling algorithm to be used.
The Nearest and Majority options are used for categorical data, such as a land-use classification. The Nearest option is the default. It is the quickest and does not change the pixel values. Do not use either of these options for continuous data, such as elevation surfaces.
The Bilinear and Cubic options are most appropriate for continuous data. It is recommended that you do not use either of these options with categorical data because the pixel values may be altered.
  • Nearest neighbor—The nearest neighbor technique will be used. It minimizes changes to pixel values since no new values are created and is the fastest resampling technique. It is suitable for discrete data, such as land cover.
  • Bilinear interpolation—The bilinear interpolation technique will be used. It calculates the value of each pixel by averaging (weighted for distance) the values of the surrounding four pixels. It is suitable for continuous data.
  • Cubic convolution—The cubic convolution technique will be used. It calculates the value of each pixel by fitting a smooth curve based on the surrounding 16 pixels. This produces the smoothest image but can create values outside of the range found in the source data. It is suitable for continuous data.
  • Majority resampling—The majority resampling technique will be used. It determines the value of each pixel based on the most popular value in a 4 by 4 window. It is suitable for discrete data.
String
Environments
Compression, Current Workspace, Extent, Geographic Transformations, NoData, Output CONFIG Keyword, Output Coordinate System, Parallel Processing Factor, Pyramid, Raster Statistics, Resampling Method, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
