An overview of the Subtypes toolset
The Subtypes toolset contains tools that create and edit subtypes, which provide a method of dividing feature classes or tables into logical groupings based on an attribute value.
One advantage of using a geodatabase to store geographic data is that you can create subtypes for features and attributes. When working with subsets of features in a feature class, you can use subtypes to assign consistent attributes and behavior to the subsets.
Tool |
Description |
Adds a new subtype to the subtypes in the input table. |
Alters the subtype name of an existing subtype code. |
Removes a subtype from the input table using its code. |
Sets the default value or code for the input table's subtype. |
Defines the field in the input table or feature class that stores the subtype codes. |
