Alter Subtype (Data Management Tools)
Summary
Alters the subtype name of an existing subtype code.
Usage
  • Subtype codes serve as stable, permanent identifiers for each subtype and cannot be altered. If you need to alter a code, create a new subtype with the desired value and delete the previous one.
Parameters
Label Explanation Data type
Input Table
The table or feature class containing the subtype to be altered.
Table View
Subtype Code
The integer code of the target subtype.
String
New Subtype Name
The new name of the target subtype.
String
Derived output
Output Table
The updated table or feature class with the altered subtype name.
Table View
Environments
Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
