An overview of the Topology toolset
The Topology toolset contains a set of tools that can be used to create and manage a geodatabase topology.
Geodatabase topologies help ensure data integrity. Using a topology provides a mechanism to perform integrity checks on data and helps validate and maintain better feature representations in a geodatabase. In addition, topologies can be used for modeling numerous spatial relationships between features. These enable support for a variety of analytic operations, such as finding adjacent features, working with coincident boundaries between features, and navigating along connected features.
Tool
Add Feature Class To Topology
Adds a feature class to a topology.
Add Rule To Topology
Adds a rule to a topology.
Create Topology
Creates a topology. The topology will not contain any feature classes or rules.
Export Topology Errors
Exports the errors and exceptions from a geodatabase topology to the target geodatabase. All information associated with the errors and exceptions, such as the features referenced by the error or exception, is exported. Once the errors and exceptions are exported, the feature classes can be accessed using any license level of ArcGIS. The feature classes can be used with the Select Layer By Location tool and can be shared with other users who do not have access to the topology.
Remove Feature Class From Topology
Removes a feature class from a topology.
Remove Rule From Topology
Removes a rule from a topology.
Set Cluster Tolerance
Sets the cluster tolerance of a topology.
Validate Topology
Validates a geodatabase topology.
Topology tools
