Set Cluster Tolerance (Data Management Tools)
Summary
Sets the cluster tolerance of a topology.
Usage
  • You cannot alter the cluster tolerance for a topology if the topology has been registered as versioned.
  • Changing the cluster tolerance will require the entire topology be validated.
  • For more information about cluster tolerance, see Topology in ArcGIS
Parameters
Label Explanation Data type
Input Topology
The topology for which you want to change the cluster tolerance.
Topology Layer
Cluster Tolerance
The value to be set as the cluster tolerance property of the selected topology. If you enter a value of zero, the default or minimum cluster tolerance will be applied to the topology.
Double
Derived output
Updated Input Topology
The updated topology.
Topology Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
