Export Topology Errors (Data Management Tools)
Summary
Exports the errors and exceptions from a geodatabase topology to the target geodatabase. All information associated with the errors and exceptions, such as the features referenced by the error or exception, is exported. Once the errors and exceptions are exported, the feature classes can be accessed using any license level of ArcGIS. The feature classes can be used with the Select Layer By Location tool and can be shared with other users who do not have access to the topology.
Usage
  • The default output location is the location of the specified topology.
  • The output of the tool consists of three feature classes, one for each supported geometry type of topology error: points, lines, and polygons. The names of each feature class are created by combining a user-defined base name appended with either PointsErrors, LineErrors, or PolygonErrors.
  • The default Base Name parameter value for the three output feature classes is the name of the specified topology.
  • Three output feature classes are always created, even if there are no topology errors of each geometry type. Use the Get Count tool to determine if any of the feature classes are empty.
  • The field collection of the output feature classes is fixed and can only be modified after exporting. Along with the standard geodatabase feature class fields (ObjectID, Shape, and optional shape length and area fields), the following fields are included and contain information regarding each topology error:
    Field name
    Type
    OriginObjectClassName
    String
    Origin Class Name
    OriginObjectID
    Integer
    Origin Feature's Object ID
    DestinationObjectClassName
    String
    Destination Class Name
    DestinationObjectID
    Integer
    Destination Feature's Object ID
    RuleType
    String
    Description of the rule that was violated, obtained from the esriTopologyRuleType enumeration
    RuleDescription
    String
    User-friendly description of the rule that was violated. This description is the same as one provided in the Topology Error Inspector.
    IsException
    Integer
    Indicates if this error is an exception. A value of 1 identifies the error as an exception.
  • Starting at ArcGIS Pro 2.6, the input topology layer can be from a topology service if the service is published with ArcGIS Enterprise 10.8.1 or later. If the layer has been added to the Contents pane, you can drag the layer to the Input Topology parameter, or you can provide the URL of the topology layer feature service, for example, https://myserver.mydomain.com/server/rest/services/myTopoService/FeatureServer/0.
Parameters
Label Explanation Data type
Input Topology
The topology from which the errors will be exported.
Topology Layer
Output Location
The output workspace in which the feature classes will be created. The default is the workspace where the topology is located. If the input is a topology service, the default will be the default geodatabase for the project.
Feature Dataset; Workspace
Base Name
The name to prefix to each output feature class. This allows you to specify unique output names when running multiple exports to the same workspace. The default is the topology name.
String
Derived output
Output point features
Point topology errors.
Feature Class
Output line features
Polyline topology errors.
Feature Class
Output polygon features
Polygon topology errors.
Feature Class
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
