An overview of the Raster toolset
The Raster toolset contains tools that perform raster data management and raster processing. These tools allow you to work with raster dataset properties and create and process raster data.
The following table lists the toolsets in the Raster toolset:
Toolset
Mosaic Dataset
Create and edit mosaic datasets.
Ortho Mapping
Create an orthorectified image mosaic from remote sensing images.
Raster Dataset
Copy, create, and mosaic raster datasets.
Raster Processing
Perform tasks to prepare raster data for use.
Raster Properties
Create, view, and edit the raster dataset properties.
An overview of the Mosaic Dataset toolset
The Mosaic Dataset toolset contains tools to manage, analyze, and display a collection of rasters.
Tool
Add Rasters To Mosaic Dataset
Adds raster datasets to a mosaic dataset from various sources, including a file, folder, table, or web service.
Alter Mosaic Dataset Schema
Defines the editing operations that nonowners have when editing a mosaic dataset in an enterprise geodatabase.
Analyze Mosaic Dataset
Performs checks on a mosaic dataset for errors and possible improvements.
Build Boundary
Updates the extent of the boundary when adding new raster datasets to a mosaic dataset that extend beyond its previous coverage.
Build Footprints
Computes the extent of every raster in a mosaic dataset. This tool is used when you have added or removed raster datasets from a mosaic dataset and want to recompute the footprints.
Build Mosaic Dataset Item Cache
Inserts the Cached Raster function as the final step in all function chains within a mosaic dataset.
Build Overviews
Defines and generates overviews on a mosaic dataset.
Build Seamlines
Generate or update seamlines for your mosaic dataset. Seamlines are used to sort overlapping imagery and produce a smoother-looking mosaic.
Calculate Cell Size Ranges
Computes the visibility levels of raster datasets in a mosaic dataset based on the spatial resolution.
Clear Pixel Cache
Clears the pixel cache associated with a mosaic dataset.
Color Balance Mosaic Dataset
Color balances a mosaic dataset so that the tiles appear seamless.
Compute Dirty Area
Identifies areas within a mosaic dataset that have changed since a specified point in time. This is used commonly when a mosaic dataset is updated or synchronized, or when derived products, such as cache, need to be updated. This tool will enable you to limit such processes to only the areas that have changed.
Compute Mosaic Candidates
Finds the image candidates in a mosaic dataset that best represent the mosaic area.
Create Mosaic Dataset
Creates an empty mosaic dataset in a geodatabase.
Create Referenced Mosaic Dataset
Creates a separate mosaic dataset from items in an existing mosaic dataset.
Define Mosaic Dataset NoData
Specifies one or more values to be represented as NoData.
Define Overviews
Lets you set how mosaic dataset overviews are generated. The settings made with this tool are used by the Build Overviews tool.
Delete Mosaic Dataset
Deletes a mosaic dataset, its overviews, and its item cache from disk.
Edit Raster Function
Adds, replaces, or removes a function chain in a mosaic dataset or a raster layer that contains a raster function.
Export Mosaic Dataset Geometry
Creates a feature class showing the footprints, boundary, seamlines or spatial resolutions of a mosaic dataset.
Export Mosaic Dataset Items
Saves a copy of processed images in a mosaic dataset to a specified folder and raster file format.
Export Mosaic Dataset Paths
Creates a table of the file path for each item in a mosaic dataset. You can specify whether the table contains all the file paths or just the ones that are broken.
Generate Exclude Area
Masks pixels based on their color or by clipping a range of values. The output of this tool is used as an input to the Color Balance Mosaic Dataset tool to eliminate areas such as clouds and water that can skew the statistics used to color balance multiple images.
Generate Raster Collection
Performs batch analysis or processing on image collections contained in a mosaic dataset. The images in the input mosaic dataset can be processed individually or as groups.
Import Mosaic Dataset Geometry
Modifies the geometry for the footprints, boundary, or seamlines in a mosaic dataset to match those in a feature class.
Merge Mosaic Dataset Items
Groups multiple items in a mosaic dataset together as one item.
Mosaic Dataset To Mobile Mosaic Dataset
Converts a mosaic dataset into a mobile mosaic dataset that's compatible with ArcGIS Maps SDKs for Native Apps. A mobile mosaic dataset resides in a mobile geodatabase.
Remove Rasters From Mosaic Dataset
Removes selected rasters from a mosaic dataset.
Repair Mosaic Dataset Paths
Resets paths to source imagery if you have moved or copied a mosaic dataset.
Set Mosaic Dataset Properties
Defines the defaults for displaying a mosaic dataset and serving it as an image service.
Split Mosaic Dataset Items
Splits mosaic dataset items that were merged together using Merge Mosaic Dataset Items.
Synchronize Mosaic Dataset
Synchronizes a mosaic dataset to keep it up to date. In addition to syncing data, you can update overviews if the underlying imagery has been changed, generate new overviews and cache, and restore the original configuration of mosaic dataset items. You can also remove paths to source data with this tool. To repair paths, use the Repair Mosaic Dataset Paths tool.
An overview of the Ortho Mapping toolset
The Ortho Mapping toolset contains tools to create an orthorectified image mosaic from remote sensing images ranging from satellite images described by the Rational Polynomial Coefficients (RPC) model and aerial images to UAV and UAS images.
For more information, see Ortho mapping in ArcGIS Pro.
Tool
Analyze Control Points
Analyzes the control point coverage and identifies the areas that need additional control points to improve the block adjust result.
Append Control Points
Combines control points to an existing control point table.
Apply Block Adjustment
Applies the geographic adjustments to the mosaic dataset items. This tool uses the solution table from the Compute Block Adjustments tool.
Build Stereo Model
Builds a stereo model of a mosaic dataset based on a user-provided stereo pair.
Computes the adjustments to the mosaic dataset. This tool will create a solution table that can be used to apply the actual adjustments.
Compute Camera Model
Estimates the exterior camera model and interior camera model from the EXIF header of the raw image and refines the camera models. The model is then applied to the mosaic dataset with an option to use a tool-generated, high-resolution digital surface model (DSM) to achieve better orthorectification.
Compute Control Points
Creates the control points between the mosaic dataset and the reference image. The control points can then be used in conjunction with tie points to compute the adjustments for the mosaic dataset.
Compute Depth Map
Uses control points and solution points to compute a depth map for each image comprising a mosaic dataset.
Compute Fiducials
Computes the fiducial coordinates in image and film space for each image in a mosaic dataset.
Compute Tie Points
Computes the tie points between overlapped mosaic dataset items. The tie points can then be used to compute the block adjustments for the mosaic dataset.
Export Frame and Camera Parameters
Exports frame and camera parameters from a mosaic dataset that contains frame imagery.
Generate Block Adjustment Report
Generates a report after performing an ortho mapping block adjustment on a mosaic dataset. The report is useful when evaluating the quality and accuracy of the ortho mapping products.
Generate Point Cloud
Generates 3D points from stereo pairs and outputs a point cloud as a set of LAS files.
Interpolate From Point Cloud
Interpolates a digital terrain model (DTM) or a digital surface model (DSM) from a point cloud.
Match Control Points
Creates matching tie points for a given ground control point and initial tie point in one of the overlapping images.
Remove Depth Map
Removes the depth map created by running the Compute Depth Map tool.
Update Interior Orientation
Refines the interior orientation for each image in the mosaic dataset by constructing an affine transformation from a fiducial table.
An overview of the Raster Dataset toolset
The Raster Dataset toolset contains tools to copy, create, and append raster datasets. A raster dataset is the basic data model for rasters. A raster dataset is an organized array of pixels, which can have a single band or many bands.
Tool
Copy Raster
Saves a copy of a raster dataset or converts a mosaic dataset into a single raster dataset.
Create Random Raster
Creates a raster dataset of random values with a distribution you define.
Create Raster Dataset
Creates an empty raster dataset.
Download Rasters
Downloads the source files from an image service or mosaic dataset.
Generate Raster From Raster Function
Generates a raster dataset from an input raster function or function chain.
Mosaic
Merges multiple existing raster datasets or mosaic datasets into an existing raster dataset.
Mosaic To New Raster
Merges multiple raster datasets into a new raster dataset.
Workspace To Raster Dataset
Merges all of the raster datasets in a folder into one raster dataset.
An overview of the Raster Processing toolset
The Raster Processing toolset contains tools to prepare data for analysis and display.
Tool
Clip Raster
Cuts out a portion of a raster dataset, mosaic dataset, or image service layer.
Composite Bands
Creates a single raster dataset from multiple bands.
Compute Pansharpen Weights
Calculates an optimal set of pan sharpened weights for new or custom sensor data.
Create Color Composite
Creates a three-band raster dataset from a multiband raster dataset.
Create Ortho Corrected Raster Dataset
Creates an orthocorrected raster dataset using a digital elevation model (DEM) and control data to accurately align imagery.
Create Pansharpened Raster Dataset
Combines a high-resolution panchromatic raster dataset with a lower-resolution multiband raster dataset to create a high-resolution multiband raster dataset for visual analysis.
Extract Subdataset
Creates a new raster dataset from a selection of an HDF or NITF dataset.
Generate Table From Raster Function
Converts a raster function dataset to a table or feature class. The input raster function should be a raster function designed to output a table or feature class.
Raster To DTED
Splits a raster dataset into separate files based on the DTED tiling structure.
Resample
Changes the spatial resolution of a raster dataset and sets rules for aggregating or interpolating values across the new pixel sizes.
Split Raster
Divides a raster dataset into smaller pieces, by tiles or features from a polygon.
An overview of the Raster Properties toolset
The Raster Properties toolset contains tools to create, delete, and edit the various properties of a raster dataset. A raster dataset has properties that are associated with it including color maps, pyramids, statistics, attribute tables, world files, and cell values.
Tool
Add Colormap
Adds a new color map or replaces an existing color map on a raster dataset.
Batch Build Pyramids
Builds pyramids for multiple raster datasets.
Batch Calculate Statistics
Calculates statistics for multiple raster datasets.
Build Pyramids
Builds raster pyramids for your raster dataset.
Build Pyramids And Statistics
Traverses a folder structure, building pyramids and calculating statistics for all the raster datasets it contains. It can also build pyramids and calculate statistics for all the items in a mosaic dataset.
Build Raster Attribute Table
Adds a raster attribute table to a raster dataset or updates an existing one. This is used primarily with discrete data.
Calculates statistics for a raster dataset or a mosaic dataset.
Convert Raster Function Template
Converts a raster function template between formats (rft.xml, json, and binary).
Delete Colormap
Removes the color map associated with a raster dataset.
Delete Raster Attribute Table
Removes the raster attribute table associated with a raster dataset.
Export Raster World File
Creates a world file based on the pixel size and the location of the upper left pixel.
Get Cell Value
Retrieves the value of a given pixel using its x, y coordinates.
Get Raster Properties
Retrieves information from the metadata and descriptive statistics about a raster dataset.
Set Raster Properties
Sets the data type, statistics, and NoData values on a raster or mosaic dataset.
