Generate Raster Collection (Data Management Tools)
Summary
Performs batch analysis or processing on image collections contained in a mosaic dataset. The images in the input mosaic dataset can be processed individually or as groups.
The rules of processing can be defined through the Collection Builder parameter and raster function parameters. It generates a new mosaic dataset of processed images. You can optionally choose to save the processed images to disk as separate files. The default condition is to append the input raster function to the mosaic dataset's existing images' function chain, and add it to the output mosaic dataset.
Usage
  • The output of this tool is a mosaic dataset with the raster function template (RFT) applied to each raster item. Since the optional parameters affect the output, you need to properly define the parameters in order to obtain the correct output.
  • If you want to generate separate image files with an RFT applied, you must define an output workspace. An RFT can be created using the Raster Function Editor.
Parameters
Label Explanation Data type
Output Raster Collection
The full path of the mosaic dataset to be created. The mosaic dataset must be stored in a geodatabase.
Mosaic Dataset
Collection Builder
The input image collection. It can be seen as a template that contains arguments such as the source mosaic dataset path, filters to extract a subset from the input data source, and so on.
Currently, this tool only supports Simple Collection, which allows you to define a single data source and a query filter, for the data source.
  • Simple collection—Allows you to define a data source and a query filter.
String
Collection Builder Arguments
The list of arguments to create a subset collection of the mosaic dataset.
This tool only supports the data source and filter to subset the mosaic dataset. The Data Source and Where Clause values must be completed, otherwise the tool cannot be executed.
Value table columns:
  • Name—The name of the collection builder arguments.
  • Value—The value of the collection builder arguments.
Value Table
Input Raster Function
(Optional)
The path to a raster function template file (.rft.xml or .rft.json). The raster function template will be applied to every item in the input mosaic dataset. The Function Editor can be used to create the template. If no RFT is defined, this tool will create the output mosaic based on the Collection Builder Arguments parameter.
String; File
Raster Function Arguments
(Optional)
The parameters associated with the function chain.
For example, if the function chain applies the NDVI function, set the visible and infrared IDs. The raster variable name of the RFT should be the Tag field value in the input data source.
  • Name—The name of the raster function argument; this is usually the name in the Tag field.
  • Value—The value of the raster function argument.
Value Table
Raster Collection Properties
(Optional)
The output mosaic dataset key properties.
The key metadata properties that are available is based on the type of sensor that captured the imagery. Some examples of key metadata properties include the following:
  • SensorName
  • ProductName
  • AcquisitionDate
  • CloudCover
  • SunAzimuth
  • SunElevation
  • SensorAzimuth
  • SensorElevation
  • Off-nadirAngle
  • BandName
  • MinimumWavelength
  • MaximumWavelength
  • RadianceGain
  • RadianceBias
  • SolarIrradiance
  • ReflectanceGain
  • ReflectanceBias
  • Name—The name of the key property.
  • Value—The value of the key property.
Value Table
Generate Rasters
(Optional)
Choose to generate raster dataset files of the mosaic dataset items, after the application of the RFT.
  • Checked—Create raster datasets on disk. You will also need to specify the Output Raster Workspace and Format parameters.
  • Unchecked—The processing defined by the raster function template will be appended to the image items from the input data source to produce an image item in the output mosaic dataset. This is the default.
Boolean
(Optional)
Defines the output location for the persisted raster datasets, if the Generate Rasters parameter is checked.
The naming convention for the output raster files is oid_<oid#>_<Unique_GUID>.
Folder; String
Format
(Optional)
The format type of the raster to be generated.
  • Tiff—Tagged Image File Format (TIFF)
  • ERDAS IMAGINE—ERDAS IMAGINE file
  • CRF—Cloud Raster Format. This is the default.
  • MRF—Meta Raster Format
String
Output Base Name
(Optional)
Defines the output base name of the persisted raster datasets, if the Generate Rasters parameter is checked on. Multiple raster dataset outputs will have a number alias appended to their base name.
The resulting mosaic dataset will reference the CRF directly without maintaining the raster function chain.
String
Environments
Parallel Processing Factor, Pyramid, Raster Statistics
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
