Build Pyramids And Statistics (Data Management Tools)
Summary
Traverses a folder structure, building pyramids and calculating statistics for all the raster datasets it contains. It can also build pyramids and calculate statistics for all the items in a mosaic dataset.
Usage
  • Building pyramids improves the display performance of raster datasets.
  • Calculating statistics allows ArcGIS applications to properly stretch and symbolize raster data for display.
  • All supported raster formats will be processed.
  • If the workspace includes a mosaic dataset, only the statistics associated with the mosaic dataset will be included. The statistics associated with the items within the mosaic dataset will not be included.
  • Wavelet compressed raster datasets, such as ECW, JPEG2000, and MrSID, do not need to have pyramids built. These formats have internal pyramids that are created upon encoding.
Parameters
Label Explanation Data type
Input Data or Workspace
The workspace that contains all the raster datasets or mosaic datasets to be processed.
If the workspace includes a mosaic dataset, only the statistics associated with the mosaic dataset will be included. The statistics associated with the items within the mosaic dataset will not be included unless the Include Source Datasets parameter is checked.
Text File; Workspace; Raster Layer; Mosaic Layer
Include Sub-directories
(Optional)
Specifies whether subdirectories will be included.
If the workspace includes a mosaic dataset, only the statistics associated with mosaic dataset will be included. The statistics associated with the items within the mosaic dataset will not be included.
  • Checked—Includes all the raster datasets within the subdirectories when loading. This is the default.
  • Unchecked—Does not include subdirectories.
Boolean
Build Pyramids
(Optional)
Specifies whether pyramids will be built.
  • Checked—Pyramids will be built. This is the default.
  • Unchecked—Pyramids will not be built.
Boolean
Calculate Statistics
(Optional)
Specify whether to calculate statistics.
  • Checked—Calculates statistics. This is the default.
  • Unchecked—Does not calculate statistics.
Boolean
(Optional)
Specify whether to calculate statistics on the source raster datasets, or calculate statistics on the raster items in a mosaic dataset. This option only applies to mosaic datasets.
  • Checked—Calculates statistics on the source data of the mosaic dataset.
  • Unchecked—Statistics will be calculated for each raster item in the mosaic dataset (on each row in the attribute table). Any functions added to the raster item will be applied before generating the statistics. This is the default.
Boolean
Block Field
(Optional)
The name of the field within a mosaic dataset's attribute table used to identify items that should be considered one item when performing some calculations and operations.
String
Estimate Mosaic Dataset Statistics
(Optional)
Specify whether to calculate statistics for the mosaic dataset (not the rasters within it). The statistics are derived from the existing statistics that have been calculated for each raster in the mosaic dataset.
  • Checked—Statistics will be calculated for the mosaic dataset.
  • Unchecked—Statistics are not calculated for the mosaic dataset. This is the default.
Boolean
X Skip Factor
(Optional)
The number of horizontal pixels between samples.
A skip factor controls the portion of the raster that is used when calculating the statistics. The input value indicates the horizontal or vertical skip factor, where a value of 1 will use each pixel and a value of 2 will use every second pixel. The skip factor can only range from 1 to the number of columns/rows in the raster.
The value must be greater than zero and less than or equal to the number of columns in the raster. The default is 1 or the last skip factor used.
Long
Y Skip Factor
(Optional)
The number of vertical pixels between samples.
The value must be greater than zero and less than or equal to the number of rows in the raster. The default is 1 or the last y skip factor used.
Long
Ignore Values
(Optional)
The pixel values that are not to be included in the statistics calculation.
The default is no value.
Long
Pyramid levels
(Optional)
The number of reduced-resolution dataset layers that will be built. The default value is -1, which will build full pyramids. A value of 0 will result in no pyramid levels.
The maximum number of pyramid levels you can specify is 29. Any value of 30 or higher will create a full set of pyramids.
Long
Skip first level
(Optional)
Specifies whether the first pyramid level will be skipped. Skipping the first level will take up slightly less disk space but will slow down performance at these scales.
  • Checked—The first pyramid level will be skipped; it will not be built.
  • Unchecked—The first pyramid level will not be skipped; it will be built. This is the default.
Boolean
Pyramid resampling technique
(Optional)
Specifies the resampling technique that will be used to build the pyramids.
  • Nearest neighbor—The value of the closest pixel will be used to assign a value to the output pixel when resampling. This is the default.
  • Bilinear—The new value of a pixel will be based on a weighted distance average of the four nearest input pixel centers.
  • Cubic—The new value of a pixel will be based on fitting a smooth curve through the 16 nearest input pixel centers.
String
Pyramid compression type
(Optional)
Specifies the compression type that will be used when building the raster pyramids.
  • Default—If the source data is compressed using a wavelet compression, pyramids will be built using the JPEG compression type; otherwise, LZ77 will be used. This is the default.
  • LZ77 Compression—The LZ77 compression algorithm will be used to build pyramids. This compression type can be used for any data type.
  • JPEG Compression—The JPEG compression algorithm will be used to build pyramids. Only data that adheres to the JPEG compression specification can use this compression type. If this compression type is specified, you can then set the Compression quality parameter value.
  • JPEG Luma and Chroma—A lossy compression using the luma (Y) and chroma (Cb and Cr) color space components will be used.
  • No compression—No compression will be used when building pyramids.
String
Compression quality (1-100)
(Optional)
The compression quality that will be used when pyramids are built with the JPEG compression type. The value must be between 0 and 100. The values closer to 100 will produce a higher-quality image, but the compression ratio will be lower.
Long
Skip Existing
(Optional)
Specify whether to calculate statistics only where they are missing, or regenerate them even if they exist.
  • Checked—Statistics will only be calculated if they do not already exist. This is the default.
  • Unchecked—Statistics will be calculated even if they already exist; existing statistics will be overwritten.
Boolean
Query Definition
(Optional)
An SQL expression to select raster datasets that will be processed.
SQL Expression
SIPS Mode
(Optional)
Specifies whether to enable building of pyramid files using key processes and algorithms defined in the Softcopy Image Processing Standard (SIPS), NGA.STND.0014.
  • Checked—Pyramids will be built using SIPS processing.
  • Unchecked—Pyramids will be built using standard subsampling methods. This is the default.
Boolean
Derived output
Updated Input Data
The updated output workspace.
Environments
Parallel Processing Factor, Pyramid, Raster Statistics
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
