Compute Pansharpen Weights (Data Management Tools)
Summary
Calculates an optimal set of pan sharpened weights for new or custom sensor data.
Usage
This tool will calculate an optimal set of pan sharpened weights, which can be used in other tools that require pan sharpened weights.
If a raster product is used as the Input Raster, the band order within the raster product template will be honored.
Parameters
| Label | Explanation | Data type |
Input Raster |
A multispectral raster that has a panchromatic band. |
Mosaic Dataset; Mosaic Layer; Raster Dataset; Raster Layer |
Panchromatic Image |
The panchromatic band associated with the multispectral raster. |
Raster Layer |
Band Indexes (Optional) |
The band order for the pan sharpened weights. If a raster product is used as the Input Raster, the band order within the raster product template will be used. |
String |
Derived output
Pan-sharpened Weights |
The output pan sharpened weights. |
String |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
