Import Mosaic Dataset Geometry (Data Management Tools)
Summary
Modifies the geometry for the footprints, boundary, or seamlines in a mosaic dataset to match those in a feature class.
Illustration
Image clipped to footprint
Usage
  • This tool matches the feature in the mosaic dataset with the feature in the feature class based on a common attribute field.
  • The footprint is not always used to clip the image in the mosaic dataset. You can change the Always Clip The Image To Its Footprint property in the Mosaic Dataset Properties dialog box on the Defaults tab.
  • If the Input Feature Class has more than 1,000 records, you should add an index on the Input Join Field by running the Add Attribute Index tool. If your mosaic dataset is very large and the join field is not indexed, the tool will take much longer to complete.
Parameters
Label Explanation Data type
Mosaic Dataset
The mosaic dataset whose geometries you want to edit.
Mosaic Layer
Target Feature Class
The geometry that you want to change.
  • Footprint—The footprint polygons in the mosaic dataset
  • Seamline—The seamline polygons in the mosaic dataset
  • Boundary—The boundary polygon in the mosaic dataset
String
Target Join Field
The field in the mosaic dataset to use as a basis for the join.
Field
Input Feature Class
The feature class with the new geometry.
Feature Layer
Input Join Field
The field in the Input Feature Class to use as a basis for the join.
If the Input Feature Class has more than 1,000 records, add an index on this field by running the Add_Attribute_Index tool. If your mosaic dataset is very large and the join field is not indexed, the tool will take much longer to complete.
Field
Derived output
Updated Mosaic Dataset
The updated mosaic dataset.
Mosaic Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
