Create Color Composite (Data Management Tools)
Summary
Creates a three-band raster dataset from a multiband raster dataset.
Usage
  • When defining the band arithmetic algorithm, you can enter a single-line algebraic formula for each expression to create a multiband output. The supported operators are unary, plus (+), minus (-), times (*), and divide (/).
  • When using a band ID in an expression, identify the band by prefixing the letter B or b to the band number.
Parameters
Label Explanation Data type
Input Raster
The input multiband raster data.
Raster Dataset; Raster Layer
Output Raster
The output three-band composite raster.
Raster Dataset
Method
Specifies the method that will be used to extract bands.
  • Band names—The band name representing the wavelength interval on the electromagnetic spectrum (such as Red, Near Infrared, or Thermal Infrared) or the polarization (such as VH, VV, HH, or HV) will be used. This is the default.
  • Band IDs—The band number (such as B1, B2, or B3) will be used.
String
Red Expression
The calculation that will be assigned to the first band.
A band name, band ID, or an algebraic expression using the bands.
The supported operators are unary: plus (+), minus (-), times (*), and divide (/).
String
Green Expression
The calculation that will be assigned to the second band.
String
Blue Expression
The calculation that will be assigned to the third band.
String
Environments
Cell Alignment, Cell Size, Compression, Current Workspace, Extent, Geographic Transformations, NoData, Output Coordinate System, Parallel Processing Factor, Pyramid, Raster Statistics, Resampling Method, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
