Define Overviews (Data Management Tools)
Summary
Lets you set how mosaic dataset overviews are generated. The settings made with this tool are used by the Build Overviews tool.
Usage
  • This tool is used when there are specific parameters you need to set to generate your overviews, such as
    • Defining the location to write the files
    • Defining an extent that varies from the boundary
    • Defining the properties of the overview images, such as the resampling or compression methods
    • Defining the overview sampling factor
    Otherwise, you can check the option to Update Overviews using the Add Rasters to Mosaic Dataset tool and the defaults will be used.
  • Use the Build Overviews tool to generate the overviews after they've been defined with this tool.
  • You can use a polygon feature class to define the footprint of the overview. If you do not wish to use all the polygons in the feature class you can make a selection on the layer in the table of contents or use a tool such as Select Layer By Attribute or Select Layer By Location to select the desired polygons.
  • The default tile size is 128 by 128. The tile size can be changed in the Environment Settings.
  • This tool can take a long time to run if the boundary contains a large number of vertices.
Parameters
Label Explanation Data type
Mosaic Dataset
The mosaic dataset that you want to build overviews on.
Mosaic Layer
Output Location
(Optional)
The folder or geodatabase to store the overviews.
Workspace
Extent from Dataset
(Optional)
A raster dataset or feature class to define the extent of the overviews.
Raster Layer; Feature Layer
Extent
(Optional)
Manually set the extent using the following minimum and maximum x and y coordinates.
The mosaic dataset boundary will determine the extent of the overviews if you do not define an extent.
Envelope
Pixel Size
(Optional)
If you prefer not to use all the raster's pyramids, specify a base pixel size at which your overviews will be generated.
The units for this parameter are the same as the spatial reference of the mosaic dataset.
Double
Number Of Levels
(Optional)
Specify the number of levels of overviews that you want to generate overviews. A value of -1 will determine an optimal value for you.
Long
Number Of Rows
(Optional)
Set the number of rows (in pixels) for each tile.
Larger values will result in fewer, larger individual overviews, and increase the likelihood that you will need to regenerate lower level overviews. A smaller value will result in more, smaller files.
Long
Number Of Columns
(Optional)
Set the number of columns (in pixels) for each tile.
Long
Overview Sampling Factor
(Optional)
Set a ratio to determine the size of the next overview. For example, if the cell size of the first level is 10, and the overview factor is 3, then the next overview pixel size will be 30.
Long
Force Overview Tiles
(Optional)
Generate overviews at all levels, or only above existing pyramid levels.
  • Checked—Create overviews at all levels.
  • Unchecked—Create overviews above the raster pyramid levels. This is the default.
Boolean
Resampling Method
(Optional)
Choose an algorithm for aggregating pixel values in the overviews.
  • Nearest—The fastest resampling method because it minimizes changes to pixel values. Suitable for discrete data, such as land cover. If the Raster Metadata Data Type is thematic, then nearest neighbor will be the default.
  • Bilinear—Calculates the value of each pixel by averaging (weighted for distance) the values of the surrounding 4 pixels. Suitable for continuous data.This is the default, unless the Raster Metadata Data Type is thematic.
  • Cubic—Calculates the value of each pixel by fitting a smooth curve based on the surrounding 16 pixels. Produces the smoothest image, but can create values outside of the range found in the source data. Suitable for continuous data.
String
Compression Method
(Optional)
Define the type of data compression to store the overview images.
  • JPEG—A lossy compression. This is the default, unless the Raster Metadata Data Type is thematic. This compression method is only valid if the mosaic dataset items adhere to JPEG specifications.
  • JPEG Luna and Chroma—A lossy compression using the luma (Y) and chroma (Cb and Cr) color space components.
  • None—No data compression.
  • LZW—A lossless compression. If the Raster Metadata Data Type is thematic, then nearest neighbor will be the default.
String
Compression Quality
(Optional)
Choose a value from 1 - 100. Higher values generate better quality outputs, but they create larger files.
Long
Derived output
Updated Mosaic Dataset
The updated mosaic dataset.
Mosaic Layer
Environments
Extent, Parallel Processing Factor, Tile Size
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
