Batch Calculate Statistics (Data Management Tools)
Summary
Calculates statistics for multiple raster datasets.
Usage
  • A skip factor controls the portion of the raster that is used when calculating the statistics. The input value indicates the horizontal or vertical skip factor, where a value of 1 will use each pixel and a value of 2 will use every second pixel. The skip factor can only range from 1 to the number of columns/rows in the raster.
  • Calculating statistics on the Esri Grid and the RADARSAT2 formats always uses a skip factor of 1.
  • The skip factors for raster datasets stored in a file geodatabase or an enterprise geodatabase are quite different. First, if the x and y skip factors are different, the smaller skip factor will be used for both the x and y skip factors. Second, the skip factor is related to the pyramid level that most closely fits the skip factor chosen. If the skip factor value is not equal to the number of pixels in a pyramid (for example, if the skip factor is 5 and the closest pyramid level is 4 x 4 pixels, which is level 2), the software will round down to the next pyramid level (in this case, 2) and use that value as the skip factor.
  • A skip factor is not used for all raster formats. The raster formats that will calculate statistics and take advantage of the skip factor include TIFF, IMG, NITF, DTED, RAW, ADRG, CIB, CADRG, DIGEST, GIS, LAN, CIT, COT, ERMapper, ENVI DAT, BIL, BIP, BSQ, and geodatabase.
  • The Ignore Values option allows you to exclude a specific value from the calculation of statistics. You may want to ignore a value if it is a NoData value or if it will skew your calculation.
Parameters
Label Explanation Data type
Input Raster Datasets
The input raster datasets.
Raster Dataset
X Skip Factor
(Optional)
The number of horizontal pixels between samples.
The value must be greater than zero and less than or equal to the number of columns in the raster. The default is 1 or the last skip factor used.
The skip factors for raster datasets stored in a file geodatabase or an enterprise geodatabase are different. First, if the x and y skip factors are different, the smaller skip factor will be used for both the x and y skip factors. Second, the skip factor is related to the pyramid level that most closely fits the skip factor chosen. If the skip factor value is not equal to the number of pixels in a pyramid layer, the number is rounded down to the next pyramid level, and those statistics are used.
Long
Y Skip Factor
(Optional)
The number of vertical pixels between samples.
The value must be greater than zero and less than or equal to the number of rows in the raster. The default is 1 or the last y skip factor used.
Long
Ignore values
(Optional)
The pixel values that are not to be included in the statistics calculation.
The default is no value.
Double
Skip Existing
(Optional)
Specifies whether statistics will be calculated only when they are missing or will be regenerated even if they exist.
  • Checked—Statistics will be calculated even if they already exist, and existing statistics will be overwritten. This is the default.
  • Unchecked—Statistics will only be calculated if they do not already exist.
Boolean
Derived output
Batch Calculate Statistics Succeeded
Returns whether the tool was successful.
Boolean
Environments
Current Workspace, Raster Statistics, Scratch Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
