Edit Raster Function (Data Management Tools)
Summary
Adds, replaces, or removes a function chain in a mosaic dataset or a raster layer that contains a raster function.
Usage
  • To apply the rft.xml to items in a mosaic dataset, you must select the items in the attribute table or define a query using the Make Mosaic Layer tool.
  • Database fragmentation and frequent data manipulation can significantly increase the size of a mosaic dataset. If the database size is large due to constant transactions, run the Compact tool.
Parameters
Label Explanation Data type
Input Raster
The mosaic dataset or a raster layer. If you use a raster layer, it must have a function applied.
Mosaic Layer; Raster Layer
Mosaic Dataset Items
(Optional)
Determines if edits affect functions or the entire mosaic dataset.
  • Checked—Edits affect the functions associated with all of the items within the mosaic dataset.
  • Unchecked—Edits affect the functions associated with the mosaic dataset. This is the default.
Boolean
Edit Options
(Optional)
Insert, replace, or remove a function chain.
  • Insert—Insert the function chain above the Function Name of the existing chain. Specify the function chain below in the Function Name parameter. This is the default.
  • Replace—Replace the existing function chain with the function chain specified in this tool. Specify the function chain below in the Function Name parameter.
  • Remove—Remove the function chain starting from the function specified in the Function Name parameter.
String
Raster Function Template
(Optional)
Choose the function chain (rft.xml file) that you want to insert or replace.
File
Function Name
(Optional)
Choose where to insert, replace, or remove the function chain within the existing function chain.
If you Insert the function, it will be inserted above the function specified in the Function Name parameter.
String
Derived output
Updated Dataset
The updated mosaic dataset.
Environments
Current Workspace, Scratch Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
