List of raster functions
The raster functions allow you to define processing operations that can be applied to one or more rasters. These functions are applied to the raster data on the fly as the data is accessed and viewed. This means they can be applied quickly, without the time it would otherwise take to create a processed file on disk. The raster functions are organized in a raster function template, allowing you to create various processed products by chaining together multiple functions.
Global raster functions can be chained together with other functions, but they process data on a specified resolution and extent. Global functions can be identified by the hammer picture within the function button. They work similarly to geoprocessing tools and can use environment settings that you specify. To learn more, see Global functions.
All local raster functions—more than 100—support multidimensional rasters as inputs. Global functions do not support multidimensional rasters as inputs.
You can change the properties of a raster function on the General tab, including the name, description, output pixel type, and multidimensional rules.
Analysis
Function
License Requirement
Binary Thresholding
Divides the raster into two distinct classes using the Otsu method, which distinguishes between background and foreground in imagery by creating two classes with minimal intraclass variance.
ArcGIS Pro Basic
CCDC Analysis
Evaluates changes in pixel values over time using the Continuous Change Detection and Classification (CCDC) method and generates a change analysis raster containing the model results.
Image Analyst
Compute Change
Computes the differences between two categorical or continuous raster datasets.
Image Analyst
Detect Change Using Change Analysis
The Detect Change Using Change Analysis function generates a raster layer containing pixel date-of-change information using the change analysis raster. The change analysis raster must be generated by the Analyze Changes Using CCDC tool or the Analyze Changes Using LandTrendr tool, or the CCDC Analysis raster function or the LandTrendr Analysis raster function.
Image Analyst
Generate Trend
Estimates the trend for each pixel along a dimension for a given variable in a multidimensional raster.
Image Analyst
Gradient
Calculates the gradient along x, y, x,y, or a given dimension.
Image Analyst
Heat Index
Calculates the apparent temperature based on air temperature and humidity.
ArcGIS Pro Basic
Kernel Density
Calculates a magnitude-per-unit area from point or polyline features, using a kernel function to fit a smoothly tapered surface to each point or polyline.
Spatial Analyst
LandTrendr Analysis
Evaluates changes in pixel values over time using the Landsat-based detection of trends in disturbance and recovery (LandTrendr) method and generates a change analysis raster containing the model results.
Image Analyst
NDVI
Calculates the normalized difference vegetation index (NDVI) values using the red and near-infrared bands.
ArcGIS Pro Basic
NDVI Colorized
Computes the NDVI from the input image and applies a color map to the result.
ArcGIS Pro Basic
Predict Using Trend
Generates a forecasted layer using the output from the Generate Trend function.
Image Analyst
Process Raster Collection
Processes each slice in a multidimensional raster layer or each item in a mosaic layer.
Image Analyst or Spatial Analyst
Tasseled Cap Transformation
Provides standardized detection of human-made features, soil, and vegetation by measuring levels of brightness, vegetation, and wetness.
ArcGIS Pro Basic
Weighted Overlay
Overlays several rasters using a common measurement scale and weights each according to its importance.
Spatial Analyst
Weighted Sum
Weights and adds an array of rasters on a cell-by-cell basis.
Wind Chill
Calculates the apparent temperature based on air temperature and wind speed.
ArcGIS Pro Basic
Appearance
Function
License Requirement
Contrast and Brightness
Adjusts the difference between colors and overall lightness of the image.
ArcGIS Pro Basic
Convolution
Filters an image, which can be used to sharpen, blur, detect edges in an image, or other kernel-based enhancements.
ArcGIS Pro Basic
Pansharpen
Enhances the spatial resolution of a multiband image by fusing it with a higher-resolution panchromatic image.
ArcGIS Pro Basic
Statistics and Histogram
Defines the descriptive statistics for a dataset or uses the distribution from another dataset.
ArcGIS Pro Basic
Stretch
Enhances an image by changing properties, such as brightness, contrast, and gamma, through multiple stretch types.
ArcGIS Pro Basic
Classification
Function
License Requirement
Classify
Applies the appropriate classifier and associated training data specified in the .ecd training file to a raster dataset or segmented raster.
Linear Spectral Unmixing
Performs subpixel classification and calculates the fractional abundance of different land-cover types for individual pixels.
ML Classify
Uses the maximum likelihood algorithm to assign pixels to a class.
Predict Using Regression
Computes a predicted raster based on raster data inputs and a regression model from the Train Random Trees Regression Model tool.
Image Analyst
Region Grow
Grows regions from seed points.
ArcGIS Pro Basic
Region Pixel Count
Identifies connected regions with the same pixel value and returns a raster whose value is the number of pixels in the region it belongs to.
ArcGIS Pro Basic
Segment Mean Shift
Groups pixels that are adjacent and have similar spectral or spatial characteristics into segments. This can be used as a second raster in the Classify function.
Conversion
Function
License Requirement
Color Model Conversion
Converts the color model of an image from either the hue, saturation, and value (HSV) model to red, green, and blue (RGB), or from RGB to HSV.
ArcGIS Pro Basic
Colormap
Transforms the pixel values to display the raster data as a grayscale or RGB image, based on a color map.
ArcGIS Pro Basic
Colormap To RGB
Converts a single-band raster with a color map to a three-band RGB raster.
ArcGIS Pro Basic
Grayscale
Converts a multiband raster into a single-band grayscale raster.
ArcGIS Pro Basic
LAS Dataset To Raster
The LAS Dataset To Raster function is used to render lidar data managed using the LAS dataset. The function will be used when you add lidar data to a mosaic dataset using the LAS Dataset raster type. With this function, you need to specify both input and output properties. Due to the resolution of the data and the time it can take to convert the point data to raster data, this function will write preprocessed raster data files to an output location (as cache).
ArcGIS Pro Basic
LAS to Raster
Renders lidar data stored using the LAS file format. The function is used when you add lidar data to a mosaic dataset using the LAS raster type.
ArcGIS Pro Basic
Rasterize Attributes
Enriches a raster by adding bands derived from values of specified attributes from an external table or a feature service.
ArcGIS Pro Basic
Rasterize Features
Converts features to rasters. Features are assigned pixel values based on the feature's field, such as OBJECTID. Optionally, the pixel values can be based on a user-defined value field in the input feature's attribute table.
ArcGIS Pro Basic
Spectral Conversion
Applies a matrix to a multiband image to convert a false-color image to a pseudocolor image.
ArcGIS Pro Basic
Terrain To Raster
Render multipoint data managed using a terrain stored in a geodatabase.
ArcGIS Pro Basic
Trend to RGB
Converts a trend raster to a three-band (red, green, and blue) raster. The trend raster is generated from the Generate Trend raster function or the CCDC Analysis raster function.
Image Analyst
Unit Conversion
Converts from one unit of measurement to another.
ArcGIS Pro Basic
Vector Field
Converts data with magnitude and direction values into vectors.
ArcGIS Pro Basic
Correction
Function
License Requirement
Apparent Reflectance
Adjusts image brightness values based on sun elevation, acquisition date, and the gain and bias settings for each band. The applicable sensors are Landsat, IKONOS, and QuickBird.
ArcGIS Pro Basic
Geometric
Orthorectifies imagery by incorporating an elevation model.
ArcGIS Pro Basic
Data management
Function
License Requirement
Aggregate
Generates a reduced-resolution version of a raster.
Spatial Analyst
Aggregate Multidimensional Raster
Creates a multidimensional raster layer by combining existing multidimensional raster variable data along a dimension.
Attribute Table
Uses an attribute table to symbolize a single-band raster. This is useful when you want to present imagery with specific labels and colors. If your table contains fields named red, green, and blue, values within those fields are used like a color map when rendering the image.
ArcGIS Pro Basic
Boundary Clean
Smooths the boundary between zones.
Spatial Analyst
Buffered function
Buffers the last accessed pixel blocks.
ArcGIS Pro Basic
Cached Raster
The Cached Raster function creates a preprocessed cache at the point in the function chain where it's added. It is typically inserted in a function chain before the functions that can impede performance due to more computationally intensive processing. These functions can include Convolution, Band Arithmetic, Pansharpen, or Geometric. Multiple Arithmetic functions are also computationally intensive.
ArcGIS Pro Basic
Clip
Clips a raster using a rectangular shape according to the extents defined or clips a raster to the shape of an input polygon feature class. The shape defining the clip can clip out the extent of the raster or clip out an area within the raster.
ArcGIS Pro Basic
Composite Bands
Combines multiple rasters into one multiband raster.
ArcGIS Pro Basic
Constant
The Constant function creates a virtual raster with a single pixel value that can be used in raster function templates and to process a mosaic dataset.
ArcGIS Pro Basic
Create Color Composite
Creates a three-band raster from a multiband raster layer in which each band can use an algebraic calculation based on band algebra.
ArcGIS Pro Basic
Expand
Expands specified zones of a raster by zones by a specified number of cells.
Spatial Analyst
Extract Bands
Reorders or extracts bands from a raster.
ArcGIS Pro Basic
Geometric Median
Calculates the geometric median across pixels in a time series of multiband imagery.
Image Analyst
Interpolate Irregular Data
Interpolates from point clouds or irregular grids.
ArcGIS Pro Basic
Interpolate Raster By Dimension
Interpolates a multidimensional raster at specified dimension values using adjacent slices.
Key Metadata
Allows you to insert or override key metadata of a raster.
Key metadata is extracted from the raster's metadata and is generally associated with the following: a raster product, a mosaic dataset created using the product description, or each raster within a mosaic dataset that was added using specific raster types.
ArcGIS Pro Basic
Label Bad Bands
Allows you to specify a set of bands using ranges or lists to be labeled as bad. The function supports both multispectral and hyperspectral images and maintains the same band order as the input.
ArcGIS Pro Basic
Mask
Creates NoData by defining a range of pixel values. Any values outside the range return as NoData.
ArcGIS Pro Basic
Merge Raster
Groups or merges a collection of rasters.
ArcGIS Pro Basic
Mosaic Rasters By Band Indices
Mosaics overlapping pixels of a collection of images based on criteria defined by their band indices.
ArcGIS Pro Basic
Mosaic Rasters
Stitches a set of raster datasets together to create one dataset.
ArcGIS Pro Basic
Multidimensional Filter
Creates a raster layer from a multidimensional raster dataset by slicing data along defined variables and dimensions.
ArcGIS Pro Basic
Adds a multidimensional dataset as a multidimensional raster layer.
ArcGIS Pro Basic
Nibble
Replaces selected cells of a raster with the value of their nearest neighbor. This is useful for editing areas of a raster in which the data may be erroneous.
Spatial Analyst
Random
Creates a virtual raster with random pixel values that can be used in a mosaic dataset.
ArcGIS Pro Basic
Raster Info
Modifies properties of the raster, such as bit depth, a NoData value, cell size, extent, and so on.
ArcGIS Pro Basic
Recast
Dynamically modifies the function parameter used in a mosaic dataset or image service without physically persisting the changes.
ArcGIS Pro Basic
Region Group
Records, for each cell in the output, the identity of the connected region to which that cell belongs. A unique number is assigned to each region.
Spatial Analyst
Reproject
Modifies the projection of a raster dataset, mosaic dataset, or raster item in a mosaic dataset. It can also resample the data to a new cell size and define an origin.
ArcGIS Pro Basic
Resample
Changes the spatial resolution of a dataset.
ArcGIS Pro Basic
Shrink
Shrinks specified zones of a raster by a specified number of cells.
Spatial Analyst
Subset Bands
Extract a subset of bands using ranges or lists.
ArcGIS Pro Basic
Swath
Interpolates from irregular grids or swath data.
ArcGIS Pro Basic
Transpose Bits
Unpacks the bits of the input pixel and maps them to specified bits in the output pixel. The purpose of this function is to manipulate bits from a couple of inputs, such as the Landsat 8 quality band products.
ArcGIS Pro Basic
Distance
Function
License Requirement
Distance Accumulation function
Calculates accumulated distance for each cell to sources, allowing for straight-line distance, cost distance, and true surface distance, as well as vertical and horizontal cost factors.
Spatial Analyst
Distance Allocation function
Calculates distance allocation for each cell to the provided sources based on straight-line distance, cost distance, and true surface distance, as well as vertical and horizontal cost factors.
Spatial Analyst
Least Cost Corridor function
Calculates the sum of two accumulative cost distance rasters with the option to apply a threshold based on percentage or accumulative cost.
Spatial Analyst
Optimal Path As Raster function
Calculates the optimal path from destinations to sources.
Spatial Analyst
Distance (Legacy)
Function
License Requirement
Corridor function
Calculates the sum of accumulative costs for two input accumulative cost rasters.
The Least Cost Corridor function provides enhanced functionality or performance.
Spatial Analyst
Cost Allocation function
Calculates, for each cell, its least-cost source based on the least accumulative cost over a cost surface.
The Distance Allocation function provides enhanced functionality or performance.
Spatial Analyst
Cost Back Link function
Defines the neighbor that is the next cell on the least-accumulative cost path to the least-cost source.
The Distance Accumulation function provides enhanced functionality or performance.
Spatial Analyst
Cost Distance function
Calculates the least-accumulative cost distance for each cell from or to the least-cost source over a cost surface.
Spatial Analyst
Cost Path function
Calculates the least-cost path from a source to a destination.
The Optimal Path As Raster function provides enhanced functionality or performance.
Spatial Analyst
Euclidean Allocation function
Calculates, for each cell, the nearest source based on Euclidean distance.
Spatial Analyst
Euclidean Back Direction function
Calculates, for each cell, the direction, in degrees, to the neighboring cell along the shortest path back to the closest source while avoiding barriers.
Spatial Analyst
Euclidean Direction function
Calculates, for each cell, the direction, in degrees, to the nearest source.
Spatial Analyst
Euclidean Distance function
Calculates, for each cell, the Euclidean distance to the closest source.
Spatial Analyst
Least Cost Path function
Calculates the least-cost path from a source to a destination. The least accumulative cost distance is calculated for each cell over a cost surface to the nearest source. This produces an output raster that records the least-cost path, or paths, from selected locations to the closest source cells defined within the accumulative cost surface, in terms of cost distance.
The Distance Accumulation function and Optimal Path As Raster function provide enhanced functionality or performance.
Spatial Analyst
Path Distance function
Calculates, for each cell, the least accumulative cost distance from or to the least-cost source, while accounting for surface distance along with horizontal and vertical cost factors.
Spatial Analyst
Path Distance Allocation function
Calculates the least-cost source for each cell based on the least accumulative cost over a cost surface, while accounting for surface distance along with horizontal and vertical cost factors.
Provides enhanced functionality or performance.
Spatial Analyst
Path Distance Back Link function
Defines the neighbor that is the next cell on the least accumulative cost path to the least-cost source, while accounting for surface distance along with horizontal and vertical cost factors.
Spatial Analyst
Hydrology
Function
License Requirement
Fill function
Fills sinks and peaks in an elevation surface raster to remove small imperfections in the data.
Spatial Analyst
Flow Accumulation function
Creates a raster layer of accumulated flow into each cell. A weight factor can optionally be applied.
Spatial Analyst
Flow Direction function
Creates a raster layer of flow direction from each cell to its steepest downslope neighbor.
Spatial Analyst
Flow Distance function
Computes the minimum downslope horizontal or vertical distance to cell(s) on a stream or river into which they flow.
Spatial Analyst
Flow Length function
Creates a raster layer of upstream or downstream distance, or weighted distance, along the flow path for each cell.
Spatial Analyst
Sink function
Creates a raster layer identifying all sinks or areas of internal drainage.
Spatial Analyst
Snap Pour Point function
Snaps pour points to the cell of highest flow accumulation within a specified distance.
Spatial Analyst
Stream Link function
Assigns unique values to sections of a raster linear network between intersections.
Spatial Analyst
Stream Order function
Creates a raster layer that assigns a numeric order to segments of a raster representing branches of a linear network.
Spatial Analyst
Watershed function
Determines the contributing area above a set of cells in a raster.
Spatial Analyst
Math
Function
License Requirement
Abs
Calculates the absolute value of the pixels in a raster.
Arithmetic
Uses the pixel values to calculate mathematical operations on overlapping rasters.
ArcGIS Pro Basic
Band Arithmetic
Calculates indexes using the predefined formulas or user-defined expressions.
ArcGIS Pro Basic
Calculator
Computes a raster from a mathematical expression based on the raster bands.
Divide
Divides the values of two rasters on a pixel-by-pixel basis.
Exp
Calculates the base e exponential of the pixels in a raster.
Exp10
Calculates the base 10 exponential of the pixels in a raster.
Exp2
Calculates the base 2 exponential of the pixels in a raster.
Float
Converts each pixel value of a raster into a floating-point representation.
Int
Converts each pixel value of a raster to an integer by truncation.
Ln
Calculates the natural logarithm (base e) of each pixel in a raster.
Log10
Calculates the base 10 logarithm of each pixel in a raster.
Log2
Calculates the base 2 logarithm of each pixel in a raster.
Minus
Subtracts the value of the second input raster from the value of the first input raster on a pixel-by-pixel basis.
Mod
Finds the remainder (modulo) of the first raster when divided by the second raster on a pixel-by-pixel basis.
Negate
Changes the sign (multiplies by -1) of the pixel values of the input raster on a pixel-by-pixel basis.
Plus
Adds (sums) the values of two rasters on a pixel-by-pixel basis.
Power
Raises the pixel values in a raster to the power of the values found in another raster.
Round Down
Returns the next lower integer, as a floating-point value, for each pixel in a raster.
Round Up
Returns the next higher integer, as a floating-point value, for each pixel in a raster.
Square
Calculates the square of the pixel values in a raster.
Square Root
Calculates the square root of the pixel values in a raster.
Times
Multiplies the values of two rasters on a pixel-by-pixel basis.
Math: Conditional
Function
License Requirement
Con
Performs a conditional if/else evaluation on each of the input cells of an input raster.
Set Null
Sets the identified pixels to NoData, based on the specified criteria.
Math: Logical
Function
License Requirement
Bitwise And
Performs a Bitwise And operation on the binary values of two input rasters.
Bitwise Left Shift
Performs a Bitwise Left Shift operation on the binary values of two input rasters.
Bitwise Not
Performs a Bitwise Not (complement) operation on the binary value of an input raster.
Bitwise Or
Performs a Bitwise Or operation on the binary values of two input rasters.
Bitwise Right Shift
Performs a Bitwise Right Shift operation on the binary values of two input rasters.
Bitwise Xor
Performs a Bitwise eXclusive Or operation on the binary values of two input rasters.
Boolean And
Performs a Boolean And operation on the pixel values of two input rasters.
If both input values are true (nonzero), the output value is 1. If one or both input values are false (zero), the output value is 0.
Boolean Not
Performs a Boolean Not (complement) operation on the pixel values of the input raster.
If the input values are true (nonzero), the output value is 0. If the input values are false (zero), the output value is 1.
Boolean Or
Performs a Boolean Or operation on the cell values of two input rasters.
If one or both input values are true (nonzero), the output value is 1. If both input values are false (zero), the output value is 0.
Boolean Xor
Performs a Boolean eXclusive Or operation on the cell values of two input rasters.
If one input value is true (nonzero) and the other value is false (zero), the output value is 1. If both input values are true or both are false, the output value is 0.
Equal To
Performs an equal-to operation on two rasters on a pixel-by-pixel basis.
Greater Than
Performs a Relational greater-than operation on two inputs on a pixel-by-pixel basis.
Returns a value of 1 for pixels where the first raster is greater than the second raster and a value of 0 for pixels where the first raster is not greater than the second raster.
Greater Than Equal
Performs a Relational greater-than-or-equal-to operation on two inputs on a pixel-by-pixel basis.
Returns a value of 1 for pixels where the first raster is greater than or equal to the second raster and a value of 0 for pixels where the first raster is not greater than or equal to the second raster.
Is Null
Determines which values from the input raster are NoData on a pixel-by-pixel basis.
Returns a value of 1 if the input value is NoData and a value of 0 for pixels that are not NoData.
Less Than
Performs a Relational less-than operation on two inputs on a pixel-by-pixel basis.
Returns a value of 1 for pixels where the first raster is less than the second raster.
Less Than Equal
Performs a Relational less-than-or-equal-to operation on two inputs on a pixel-by-pixel basis.
Returns a value of 1 for pixels where the first raster is less than or equal to the second raster and a value of 0 where it is not less than or equal to the second raster.
Not Equal
Performs a Relational not-equal-to operation on two inputs on a pixel-by-pixel basis.
Returns a value of 1 for pixels where the first raster is not equal to the second raster and a value of 0 for pixels where it is equal to the second raster.
Math: Trigonometric
Function
License Requirement
ACos
Calculates the inverse cosine of the pixels in a raster.
ACosH
Calculates the inverse hyperbolic cosine of the pixels in a raster.
ASin
Calculates the inverse sine of the pixels in a raster.
ASinH
Calculates the inverse hyperbolic sine of the pixels in a raster.
ATan
Calculates the inverse tangent of the pixels in a raster.
ATan2
Calculates the inverse tangent (based on x,y) of the pixels in a raster.
ATanH
Calculates the inverse hyperbolic tangent of the pixels in a raster.
Cos
Calculates the cosine of the pixels in a raster.
CosH
Calculates the hyperbolic cosine of the pixels in a raster.
Sin
Calculates the sine of the pixels in a raster.
SinH
Calculates the hyperbolic sine of the pixels in a raster.
Tan
Calculates the tangent of the pixels in a raster.
TanH
Calculates the hyperbolic tangent of the pixels in a raster.
Reclass
Function
License Requirement
Lookup
Creates a new raster by looking up values found in another field in the table of the input raster.
ArcGIS Pro Basic
Remap
Allows you to group pixel values together and assign the group a new value.
ArcGIS Pro Basic
Zonal Remap
Allows you to remap pixels in a raster based on zones defined in another raster and zone-dependent value mapping defined in a table.
ArcGIS Pro Basic
SAR
Function
License Requirement
Complex
Computes the amplitude or phase values given a complex raster layer. It can also compute amplitude, phase, or complex values given a real and imaginary data type as the raster input.
ArcGIS Pro Basic
Radar Calibration
Corrects systematic errors in synthetic aperture radar (SAR) data and transforms radar reflectivity into radar backscatter on a reference plane.  Calibrating SAR data is required to retrieve meaningful backscatter that can be related directly to the physical properties of features in an image.
ArcGIS Pro Basic
SAR Indices
Computes various synthetic aperture radar (SAR) indices for SAR data, such as Radar Vegetation Index (RVI), Radar Forest Degradation Index (RFDI), and Canopy Structure Index (CSI).
Image Analyst
Sentinel-1 Radiometric Correction
Converts the Sentinel-1 synthetic aperture radar (SAR) reflectivity into physical units of normalized backscatter by normalizing the reflectivity using a reference plane.
ArcGIS Pro Basic
Sentinel-1 Thermal Noise Removal
Corrects backscatter disturbances caused by thermal noise, resulting in a more seamless synthetic aperture radar (SAR) Sentinel-1 image.
ArcGIS Pro Basic
Speckle
Removes speckle in radar datasets and smooths the grainy salt and pepper effect, while retaining edges and sharp features in the image.
ArcGIS Pro Basic
Terrain Flatten
Corrects the input synthetic aperture radar (SAR) data for radiometric distortions due to topography.
Image Analyst
Corrects backscatter disturbances caused by thermal noise in the input synthetic aperture radar (SAR) data, resulting in a more seamless image.
Image Analyst
Statistical
Function
License Requirement
ArgStatistics
Orders raster bands into an array and identifies the band that has the minimum, maximum, median, or duration of pixel values.
ArcGIS Pro Basic
Cell Statistics
Calculates statistics from multiple rasters on a pixel-by-pixel basis.
Dimensional Moving Statistics
Calculates statistics over a moving window on multidimensional data along a specified dimension.
Focal Statistics
Calculates statistics on the cells within a neighborhood around each cell of an input raster. Several shapes of neighborhood are available.
Statistics
Defines a neighborhood and calculates the statistics within those pixels.
ArcGIS Pro Basic
Zonal Statistics
Calculates statistics on values of a raster within the zones of another dataset.
Surface
Function
License Requirement
Aspect
Shows the direction that each pixel is facing.
ArcGIS Pro Basic
Aspect-Slope
Creates a raster layer that simultaneously displays the aspect and slope of a surface.
ArcGIS Pro Basic
Contour
Generates contour lines by joining points with the same elevation from a raster elevation layer. The contours are isolines created as rasters for visualization.
ArcGIS Pro Basic
Curvature
Calculates the curvature of a raster surface, optionally including profile and plan curvature.
ArcGIS Pro Basic
Elevation Void Fill
Creates pixels where holes exist in your elevation data.
ArcGIS Pro Basic
Hillshade
Creates a 3D representation of the surface, with the sun's relative position taken into account for shading the image.
ArcGIS Pro Basic
Shaded Relief
Creates a multiband, color-coded, 3D representation of the surface. The sun's relative position is taken into account for shading the image.
ArcGIS Pro Basic
Slope
Calculates the rate of change from one pixel value to its neighbors.
ArcGIS Pro Basic
Surface Parameters
Determines parameters of a raster surface such as aspect, slope, and curvature using geodesic methods.
Spatial Analyst
Viewshed
Determines the raster surface locations visible to a set of observer features using geodesic methods.
Spatial Analyst
