Exp10 function
Available with Image Analyst license.
Available with Spatial Analyst license.
Overview
Calculates the base 10 exponential of the pixels in a raster.
Notes
The input Raster can be an integer or a floating point. The output of this tool is always a floating point, regardless of the input type.
The input Raster can be positive or negative. The output of this tool will always be positive.
If the input is a multiband raster, the output will be a multiband raster. The function will perform the operation on each band in the input.
If the input is a multidimensional raster, all slices from all variables will be processed, and the output will be a multidimensional raster.
Parameters
Parameter name |
Description |
Raster |
The input values for which to find the base 10 exponential. |
Extent Type |
Choose which extent should be used in the output raster:
Cellsize Type |
Choose which cell size to use in the output raster. If all the input cell sizes are the same, all the options will yield the same results.
