An overview of the Math toolset
Available with Spatial Analyst license.
Available with Image Analyst license.
The Math toolset contains tools that perform mathematical operations on rasters.
The tools are grouped into four main categories:
Math
The tools at the top level of the math toolset perform basic mathematical operations on rasters in the following categories: Arithmetic, Power, Exponential, and Logarithmic. Also included are tools that alter the sign of the raster values, as well as those involved in converting the values between integer and floating point.
Bitwise
The Bitwise math toolset contains tools that perform bitwise operations on the input rasters.
Logical
The Logical math toolset contains tools for performing logical evaluations on rasters in the following categories: Boolean, Combinatorial, Relational, and Conditional.
Trigonometric
The Trigonometric math toolset contains tools for trigonometric calculations in several categories: Regular, Inverse, Hyperbolic, and Inverse Hyperbolic.
License:
The Math tools are also available if you have an Image Analyst extension license.
Certain Math tools are also available with a 3D Analyst extension license. These tools are: Divide, Float, Int, Minus, Plus, and Times.
The following table lists the available Math toolsets and provides a brief description of each.
Tool |
Description |
General Math toolset |
The general Math tools apply a mathematical function to the input. These tools fall into several categories. The arithmetic tools perform basic mathematical operations, such as addition and multiplication. There are tools that perform various types of exponentiation operations, which includes exponentials and logarithms in addition to the basic power operations. The remaining tools are used either for sign conversion or for conversion between integer and floating point data types. |
The bitwise math tools compute on the binary representation of the input values. |
The Logical Math tools evaluate the values of the inputs and determine the output values based on Boolean logic. The tools are grouped into four main categories: Boolean, Combinatorial, Logical, and Relational. |
Trigonometric Math tools perform various trigonometric calculations on the values in an input raster. |
The following applies only to the tools at the top level of this toolset. For more details on the others, go to the appropriate sections for the Bitwise, Logical and Trigonometric mathematical operations.
Certain tools require two inputs:
Arithmetic: Plus, Minus, Times, Divide, Mod (modulus)
Power: Power
While other tools only need a single input:
Exponential: Exp, Exp2, Exp10
Logarithmic: Ln, Log2, Log10
Power: Square, Square Root
Sign: Abs, Negate
Type conversion: Float, Int, Round Down, Round Up
The following table lists the available general Math tools and provides a brief description of each:
Tool |
Description |
Calculates the absolute value of the cells in a raster. |
Divides the values of two rasters on a cell-by-cell basis. |
Calculates the base e exponential of the cells in a raster. |
Calculates the base 10 exponential of the cells in a raster. |
Calculates the base 2 exponential of the cells in a raster. |
Converts each cell value of a raster into a floating-point representation. |
Converts each cell value of a raster to an integer by truncation. |
Calculates the natural logarithm (base e) of cells in a raster. |
Calculates the base 10 logarithm of cells in a raster. |
Calculates the base 2 logarithm of cells in a raster. |
Subtracts the value of the second input raster from the value of the first input raster on a cell-by-cell basis. |
Finds the remainder (modulo) of the first raster when divided by the second raster on a cell-by-cell basis. |
Changes the sign (multiplies by -1) of the cell values of the input raster on a cell-by-cell basis. |
Adds (sums) the values of two rasters on a cell-by-cell basis. |
Raises the cell values in a raster to the power of the values found in another raster. |
Returns the next lower integer value, just represented as a floating point, for each cell in a raster. |
Returns the next higher integer value, just represented as a floating point, for each cell in a raster. |
Calculates the square of the cell values in a raster. |
Calculates the square root of the cell values in a raster. |
Multiplies the values of two rasters on a cell-by-cell basis. |
