Round Up (Spatial Analyst Tools)
Summary
Returns the next higher integer value, just represented as a floating point, for each cell in a raster.
Illustration
Round Up illustration
OutRas = RoundUp(InRas1)
Usage
  • Input values can be positive or negative.
  • The output raster from this tool is always floating-point type, regardless of the input value type.
  • If the input number has any values to the right of the decimal point, the output will be assigned the next higher integer value, but will be represented as a floating point number with no decimal portion. For example:
    Input   Output
     5.3     6.0
     4.9     5.0
     3.0     3.0
     6.5     7.0
    -0.2     0.0
    -2.8    -2.0
  • If the input is a multiband raster, the output will be a multiband raster. The tool will perform the operation on each band in the input.
  • If the input is multidimensional raster data, all slices from all variables will be processed. The output will be a multidimensional raster in CRF format.
  • See Analysis environments and Spatial Analyst for additional details on the geoprocessing environments that apply to this tool.
Parameters
Label Explanation Data type
Input raster or constant value
The input values to be rounded up.
To use a number as an input for this parameter, the cell size and extent must first be set in the environment.
Raster Layer; Constant
Return value
Output raster
The output raster.
The cell values are the result of rounding up the input values.
Raster
Environments
Auto Commit, Cell Size, Cell Size Projection Method, Current Workspace, Extent, Geographic Transformations, Mask, Output CONFIG Keyword, Output Coordinate System, Scratch Workspace, Snap Raster, Tile Size
Licensing information
  • Basic: Requires Spatial Analyst or Image Analyst
  • Standard: Requires Spatial Analyst or Image Analyst
  • Advanced: Requires Spatial Analyst or Image Analyst
