Aggregate function
Available with Spatial Analyst license.
Overview
Generates a reduced-resolution version of a raster.
Notes
Depending on the value provided for the cell factor (whether the division of the cell factor by the number of cells in a row or column leaves a remainder), the spatial extent of the input raster may not cover the same extent for the last cell in a row or column as the output raster. When this occurs, the value for the last output row or column of cells can be calculated with the available cells from the input raster that fall within the extent if the Expand extent if needed parameter is checked. If that parameter is unchecked, the output raster will be truncated by removing the last row or column of cell from the output raster.
For the Aggregation Technique settings of Maximum, Minimum, or Sum, the output raster type will be the same as that of the input raster. If the setting is Mean or Median, the output type will always be float.
Parameters
Parameter |
Description |
Raster (Required) |
The input raster to be aggregated. It can be of integer or floating point type. |
Cell Factor |
The factor by which the cell size of the input raster will be multiplied. The value must be an integer greater than 1. For example, a cell factor value of 3 results in an output cell size three times larger than that of the input raster. |
Aggregation Technique |
The method that will be used for aggregation. The values of the input cells encompassed by the coarser output cells are aggregated by one of the following statistics:
Expand extent if needed |
Specifies whether the boundaries of the input raster will be expanded when its rows or columns are not a multiple of the cell factor.
Ignore NoData in calculations |
Specifies whether NoData values will be ignored during the aggregation calculation.
