Raster Info function
Overview
The Raster Info opens a dialog with raster properties, such as the number of columns and rows, the number of bands, the pixel type, the extent, and the spatial reference. You can edit these properties by selecting a raster to use as a template.
Notes
To access the RasterInfo Properties dialog, click on the Load template raster icon next to the Raster Info parameter. Navigate to the raster dataset you want to edit, and select it. This opens the Raster Information table in the dialog, which allows you to edit the parameters enabled in the table.
Use caution when editing the raster dataset properties since the properties affect how the raster dataset is used in subsequent tools and functions.
Parameters
Parameter
Raster
The input raster.
Raster Info
Select a raster dataset to use as a template
