Extract Bands function
Overview
The Extract Bands function allows you to extract one or more bands from, or reorder the bands in, a multiband raster layer.
Use the Subset Band raster function to extract bands comprising hyperspectral imagery.
Notes
The extract Method parameter allows you to choose the type of keyword to use while extracting bands. The options are Band ID, Band Names, and Band Wavelengths.
The Combination parameter used to specify the order of the bands to extract. The bands are entered as a space-delimited list. For example, to extract bands 3, 4, and 5 from a 6-band image, enter 3 4 5. Alternatively, you can use the extract drop-down box to populate the list.
You can use the Extract Bands function before other functions, such as Arithmetic, to control which bands are used as input in the next function.
Parameters
Parameter |
Description |
Raster |
The raster product from which the band or bands will be extracted: |
Method |
Select one of the following methods for extracting bands:
Band |
Select the bands to extract from a list based on the Method parameter option used. |
Combination |
The band combination or band order. The selection list depends on the Method option specified. For example, if Method is Band Names, you can select a Blue, Green, and Red combination to extract a natural color image. |
Missing Band Action |
Specify the action that will occur when a band within the extract band list is not available.
