Predict Using Trend function
Available with Image Analyst license.
Overview
Computes a forecasted multidimensional raster layer using the output trend raster from the Generate Trend function or Generate Trend Raster geoprocessing tool.
Notes
The format of the time, depth, and height values must match the format of the dimension values used to generate the trend raster. If the trend raster was generated for the StdTime dimension, the format should be YYYY-MM-DDTHH:MM:SS, for example, 2050-01-01T00:00:00. UNIX Epoch Time and Posix Time are also common designations for time. Multiple values are separated with a semicolon.
Parameters
Parameters |
Description |
Raster |
The input multidimensional trend raster from the Generate Trend function. |
Dimension Definition |
Specifies the method used to provide prediction dimension values.
Values |
The dimension value or values to be used in the prediction. The format of the time, depth, and height values must match the format of the dimension values used to generate the trend raster. If the trend raster was generated for the StdTime dimension, the format should be YYYY-MM-DDTHH:MM:SS, for example, 2050-01-01T00:00:00. Multiple values are separated with a semicolon. |
Start |
The start date, height, or depth of the dimension interval to be used in the prediction. This parameter is required when the Dimension Definition parameter is set to By Interval. |
End |
The end date, height, or depth of the dimension interval to be used in the prediction. This parameter is required when the Dimension Definition parameter is set to By Interval. |
Value Interval |
The number of steps between two dimension values to be included in the prediction. The default value is 1. This parameter is required when the Dimension Definition parameter is set to By Interval. |
Unit |
The unit that will be used for the value interval. This parameter only applies when the dimension of analysis is a time dimension.
