Corridor function
Available with Spatial Analyst license.
Overview
Calculates the sum of accumulative costs for two input accumulative cost rasters.
Legacy:
This function is deprecated and will be removed in a future release.
The Least Cost Corridor function provides enhanced functionality or performance.
This is a global raster function.
Notes
While any two rasters can be used for the input, to obtain a meaningful result they should be unaltered accumulative cost output rasters. The order of the two inputs is irrelevant.
Parameters
Parameter name |
Description |
Distance Raster 1 (Required) |
The first input distance raster. It should be an accumulated cost distance output from Cost Distance or Path Distance. |
Distance Raster 2 (Required) |
The second input distance raster. It should be an accumulated cost distance output from Cost Distance or Path Distance. |
Environment settings
Geoprocessing environment settings for global functions are controlled at the application level. Setting processing environments in ArcGIS Pro can be done by clicking the Environments button on the Analysis tab. See Analysis environments and Spatial Analyst for additional details on environment settings.
The following environments are supported by this global function:
