Sentinel-1 Radiometric Calibration
Overview
This raster function converts the Sentinel-1 synthetic aperture radar (SAR) reflectivity into physical units of normalized backscatter by normalizing the reflectivity using a reference plane.
Calibrating SAR data is necessary to obtain meaningful backscatter that can be related to the physical properties of features in the image.
Notes
Use the Beta nought calibration method if you plan to apply terrain flattening using the Terrain Flatten function in your workflow.
Use the Gamma nought calibration method if the region of interest (ROI) does not have variable terrain and spans over tens of kilometers. This ensures that the calibrated backscatter values are independent of incident angle variations.
Only use the Sigma nought calibration method if the ROI is small and flat.
This raster function does not calibrate the Sentinel-1 datasets with older IPE (version 2.34 or earlier) because the calibration look up table for these products may be incorrect.
Parameters
Parameter |
Description |
Raster |
The input raster. |
Calibration Type |
Select one of four calibration types:
