Terrain Flatten function
Available with Image Analyst license.
Overview
Corrects the input synthetic aperture radar (SAR) data for radiometric distortions due to topography.
Notes
The input radar data must first be calibrated to beta nought. Use the Sentinel-1 Radiometric Calibration function or the Radar Calibration function to calibrate SAR data to beta nought.
If the input DEM does not span the entire SAR dataset, the tool will output NoData values for the pixels outside of the DEM extent for gamma nought and sigma nought.
The input DEM must be in the WGS84 (EPSG:4326) geographic coordinate system.
Parameters
Parameter |
Description |
Raster |
The input radar data. This raster must first be radiometrically calibrated to beta nought. |
DEM |
The input DEM. The DEM is used to estimate the local illuminated area. |
Geoid |
Specifies whether the vertical reference system of the input DEM will be transformed to ellipsoidal height. Most elevation datasets are referenced to sea level orthometric height, so a correction is required in these cases to convert to ellipsoidal height.
Calibration Type |
Specifies whether the output is terrain flattened using Sigma nought or Gamma nought.
