Square Root function
Available with Image Analyst license.
Available with Spatial Analyst license.
Overview
Calculates the square root of the pixel values in a raster.
Notes
Input values that are less than 0 will be NoData in the output raster.
The output raster is always a floating-point type, regardless of the input value type.
If the input is a multiband raster, the output will be a multiband raster. The function will perform the operation on each band in the input.
If the input is a multidimensional raster, all slices from all variables will be processed, and the output will be a multidimensional raster.
Parameters
Parameter name |
Description |
Raster |
The input values used to find the square root. |
Extent Type |
Choose which extent should be used in the output raster:
Cellsize Type |
Choose which cell size to use in the output raster. If all the input cell sizes are the same, all the options will yield the same results.
